What are the possible sources of interrupts for SX28? — Parallax Forums
basicstampedebasicstampede Posts: 214
edited 2008-09-05 12:52 in General Discussion
Hello.· I am learning about INT.· What are the possible sources of interrupt?·
Can anyone point the way to codes showing how the possible sources of interrupt is used in real code?
So far, I've seen·code to use the RTCC internal clock to call INT.
But I have not seen code on INT based on RB pin change.·
  • Peter VerkaikPeter Verkaik Posts: 3,956
    edited 2008-09-05 12:07
    Here is a nice thread about using external interrupts.
    http://forums.parallax.com/showthread.php?p=741829
    regards peter
  • basicstampedebasicstampede Posts: 214
    edited 2008-09-05 12:43
    Thanks Peter, I'll study that.
    So the only sources of INT are: 1. RTCC and 2. RB? No other sources of INT?
    Regarding RB, can I choose to trigger INT when say a) on rising edge of RB.0 b) falling edge of RB.0 c) when RB.0 is high d) RB.0 is low. All 4 of these are possible?
    INT can be triggered on RB rising edge or falling edge, not on level.
    There is also the RTCC input pin that can trigger an interrupt.
    regards peter
