Should the next Propeller be code-compatible? - Page 17 — Parallax Forums
1141517192027
    edited 2008-09-03 06:09
    Heater,
    To really save power, you need to stop all but one cog and then switch to RCSLOW mode while disabling the crystal oscillator and PLL. This will reduce consumption to about 8uA. Be sure no I/O pins are floating or sourcing current. Then, when the single cog wants to power back up, turn on the crystal oscillator and PLL, wait 10ms, then switch over to them. Then, turn your cogs back on.
    Chip Gracey
    edited 2008-09-03 06:21
    ONE THING TO CONSIDER, EVERYONE:
    The current Propeller is always going to be the one that easily lends itself to battery applications. It is fabricated in a low-leakage .35um process and its current can be reduced at runtime to just a few microamps.
    The next Propeller might leak one whole milliamp, without even clocking. This is due to a leakier, albeit faster, .18um process.
    If we were using a newer 45nm process, the leakage could run into the 100's of millamps. How would that be for progress?
    The current Propeller will always be the one to use if you don't need higher performance.
    Chip Gracey
  • Ym2413aYm2413a Posts: 630
    edited 2008-09-03 07:19
    I guess this new chip also amounts more RF noise as well right?
    Share the knowledge: propeller.wikispaces.com
    Lets make some music: www.andrewarsenault.com/hss
    edited 2008-09-03 07:23
    Ym2413a said...
    You get more of everything! The pins will toggle slightly faster, so each pin would create more noise than a current chip's pin. It mainly comes down to how many pins are toggling and whether you provide any R, RC, or LC filtering for any long traces on your circuit board.
    Are any of you interested in a low-EMI mode that would slow pin transitions way down?
    Chip Gracey
    edited 2008-09-03 07:40
    Chip Gracey (Parallax) said...
    It's not that big of a deal to me personally I was just wondering, Maybe if such a mode does help save power (low power mode) then it would be something nice.
    The RF issue is nothing a good old shielded enclosure couldn't fix and I think anyone who is worried about EMI would already have the idea of using a metal enclosure to keep RF out if anything.
    Thanks Chip. [noparse]:)[/noparse]
  • SapiehaSapieha Posts: 2,964
    edited 2008-09-03 07:51
    Hi All
    In My opinion.
    Computnig Power is more important that few more miliamps
    Sapieha
  • QuattroRS4QuattroRS4 Posts: 916
    edited 2008-09-03 08:49
    Are any of you interested in a low-EMI mode that would slow pin transitions way down ?
    This might be handy for certification of finished controllers PCB's / Machines ! It's pretty much the way 'others' do it - build their controller PCB - flash a moderate firmware version - get it certified .. once certified flash what you like .. It may sound deceptive but is common place.
    The following is 'Slightly' Off topic but relevant to Certification and aforementioned Low-EMI mode.
    Most industry sectors do it - Automotive industry 'detunes' engines at known Gov. test points to reduce emissions and increase fuel efficiency at these known test points 30mph,55mph and 70mph (europe anyway)
    leading to a large industry dedicated to mildly 'remap' your engine - essentially negating these flat spots.
    Performance Cars fitted with the likes of 'S' (Sport Mode) buttons that switch engine maps on the fly and open up flaps in the exhaust system - come with a warning 'Do not use on Public Roads' .... as if !
    EDIT: Basically,in a long winded way, I am saying YES to the suggested 'low-EMI' mode ..
    John Twomey
    'Necessity is the mother of invention'
    Those who can, do.Those who can’t, teach.
    Post Edited (QuattroRS4) : 9/3/2008 10:48:48 AM GMT
    edited 2008-09-03 08:59
    Hi Chip Gracey.
    I have one question on START/STOP COGs and Restart.
    It is posible att have it to STOP COG in midle of its program RUN and Restart on same position (Resume).
    Samt one Restart that START COG with Address in it that I specify
    Sapieha
  • heaterheater Posts: 3,370
    edited 2008-09-03 09:18
    Chip: "Are any of you interested in a low-EMI mode that would slow pin transitions way down ?"
    Software Define Radio sounds like it might benefit from LOW EMI mode pins. If Prop I can be a radio I'm sure Prop II can be a better one.
    edited 2008-09-03 09:32
    Chip: "wait 10ms, then switch over to them"
    There is the thing, huge latency on coming out of low power. Loading/Starting COGs, waiting for the clock to stabilize....
    For example I have worked on battery powered devices that required to wake from a "medium power mode " on receiving a sync signal from a modem and then immediately start reading the serial data.
    So the clocks needed to be running at a suitable rate even in a lowish (medium) power mode and state also needed to be preserved.
    Then there was a real "low power mode" more as you describe.
    So that what I was fishing for with WAITLOCK.
    With what you say about leakage it may not be so much of a gain but still getting to a few milliamps is better than a few hundred.
  • evanhevanh Posts: 17,314
    edited 2008-09-03 12:53
    heater said...
    I believe there is plenty of intermediate power levels the Prop can be setup for. From running more Cogs at idle speed to running on the internal 12 MHz clock to leaving the crystal running and just sleeping all the Cogs.
    edited 2008-09-03 15:33
    Hi Chip Gracey.
    One more Use of My proposo. LMM in 1+3 longs
    My proposo is to ad to ad increment flag to You proposed TRLONGS instruction.
    TRLONGS count,increment flags < Increment only cog_address, hub_address else both
    ············································ (Mostuseful HUB_Addres with transfer block protocols
    ············································ from and to I/O. With HUB flag on it is posible to fill block
    ············································ with specific value
    RDLONGS cog_address,hub_address
    LMM code.
    ···· TRLONGS 1,0,1 < set count to one long, no increment COG, increment HUB
    ···· NOP < LMM Code place holder
    ···· RDLONGS cog_address,hub_address
    ···· JMP LMM Code + 1 < Jump to read next long
    Ps. With Instruction LMM AD/SUB to ( RDLONGS cog_address,hub_address ) it is even posible to have JUMP in its program flow. And ( cog_address ) can hold LMM_RET address.
    Sapieha
    Post Edited (Sapieha) : 9/5/2008 2:58:03 AM GMT
  • Lord SteveLord Steve Posts: 206
    edited 2008-09-03 15:56
    Chip,
    Why must it be that the RAM is quad-port (3 reads, 1 write)?· Aren't there alternatives to this?· You don't NEED 4-port RAM, you need 4 transactions to RAM in one pipeline stage.· Could you not clock memory transactions faster·and have multiple memory transactions·in one·pipe stage?· (Kind of break the pipe stage into four single-port-RAM-friendly stages, or two dual-port-RAM-friendly stages.)· Or use both edges of the clock cycle for a pipe stage to transfer:· two reads on the first edge, a read and a write on the second edge.· Or use a hybrid...or SOMEthing.
    Since the size of the quad-port RAM seems to be prohibitive to having 16 cogs, I sure hope a lot of brainstorming went into alternatives to the brute force approach.
    Thanks for any clarification.
    edited 2008-09-03 16:02
    Does this mean that the next Propeller might require some additional considerations for cooling?
    Any idea of the current draw? (Edited for proper meaning, shouldn't post before coffee.)
    Like others I've been reading this thread with great interest in spite of the fact that a bunch
    of it is sailing over my head. Would someone mind doing a revised list of features gleaned
    from the information here in layman's English?
    OBC
    New to the Propeller?
    Getting started with a Propeller Protoboard?
    Check out: Introduction to the Proboard & Propeller Cookbook 1.4
    Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
    Got an SD card connected? - PropDOS
    Post Edited (Oldbitcollector) : 9/3/2008 5:23:27 PM GMT
  • jazzedjazzed Posts: 11,803
    edited 2008-09-03 16:10
    Would a 64 IO Prop have same power characteristics as the current Prop?
    Being able to add a parallel bus would allow a solution to·many of the constraint issues we now face especially regarding external memory and its access speed or connecting to other Propellers or devices. Propeller II production is obviously a long time away, meanwhile you have customers that need more than the current Propeller can provide.
    --Steve
    edited 2008-09-03 16:24
    There were comments in this forum on this question some time ago from Parallax. There is a design for the 64 pin Prop I that's on hold because of problems with the chip design software. Parallax is waiting for the problems to be addressed and there's no way to know when this will happen.
    edited 2008-09-03 16:40
    Yes, Mike I think we're aware of that. You are perhaps suggesting they are waiting for shoe-maker elves to fix it ? smile.gif
    --Steve
    edited 2008-09-03 17:27
    To help clear things as far as what Mike mentioned... "There is a design for the 64 pin Prop I that's on hold because of problems with the chip design software. Parallax is waiting for the problems to be addressed and there's no way to know when this will happen."
    ...Yes, this is true, but so far this problem is isolated to the 350nm 64-Pin version of the Propeller still·in layout, and NOT the 180nm version of Propeller II (also still in layout.)· We have 2 layout Engineers for·each project, myself and·Frank.· Frank placed the layout for the Prop I, and is currently working on the 350nm 64-Pin version of Prop I.· I was brought on board to layout the Prop II.· As far as the Prop II status is concerned, ALL major blocks are complete.· There are a few minor·blocks left to finish, including the·CPU and details on how it will function within each·COG ... thus the initial drive for this forum thread.· ... And yes, the CPU is a relatively minor block since it's all digital, and all of the standard cells (i.e. AND,NAND,XOR,OR,NOR, FLIP-FLOP's, etc.) are designed in a·way with standard cell pitches that·allows them to be "snapped" into place·... the difficult blocks are·usually analog where the design requires more of a balancing act to make sure things are going to operate as planned.
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 9/3/2008 5:40:59 PM GMT
    edited 2008-09-03 17:40
    (I've read thru the whole thread now, and I'm markign this post up now based on the posts earlier)
    I haven't had a chance to read thru the whole thread (I plan to though), but I did want to say that I think having a flat 32bit memory model for the new chip is the way to go.
    RAM starting at 0 and the ROM at the end of the address space instead of packed together. This will make future revisions with more RAM or ROM able to be compatible without weirdness.
    This seems to be the plan now.
    I can't imagine it being very hard a tool that converts Prop 1 code into Prop 2 code, in fact it could just be an option in the IDE. Of course it won't be able to resolve timing issues, but it could fix up the memory addressing.
    Also, what are the chances of having a version that had it's internal address and data busses exposed to allow for projects to add ram and memory mapped hardware?
    Post Edited (Roy Eltham) : 9/7/2008 12:20:48 PM GMT
    edited 2008-09-03 17:58
    Sapieha said...
    Good idea! It would be nice to be able to clear a swath of hub ram in one operation.
    Chip Gracey
    edited 2008-09-03 18:00
    Hi Chip Gracey.
    And not forget LMM in 3 clok cykles
    Sapieha
    edited 2008-09-03 18:02
    Lord Steve said...
    If you want single-clock instruction execution, this is how it must be done. It's true that you could overclock the RAM, but you could only overclock it maybe 1.5 times before it would·become the critical timing path. If it were possible to overclock it just 2 times without it becoming the critical path, then we could get away with half the silicon for a 2-port RAM, instead.
    Chip Gracey
    edited 2008-09-03 18:07
    Oldbitcollector said...
    No way! It's just going to draw more quiescent current. If the chip winds up running hot, it's not a good thing, as heat slows things down. This is where clock-gating comes in to minimize unnecessary signal transitions, which contribute to current draw, which generate heat. A hot chip is to be avoided.
    Chip Gracey
    edited 2008-09-03 18:10
    jazzed said...
    The only extra power dissipation would come from loads connected to the extra pins. Otherwise, it will have the same power characteristics of the current Propeller.
    Chip Gracey
    edited 2008-09-03 18:47
    Hi Chip Gracey.
    It is one more instruction to consider.
    I Name it ( BITsSET Position,xBits,Bits ).
    I am not sure If it is posible that it must have dedicated Long address register Maybe in coniunction with
    WRLONGS cog_address,hub_address
    Useful to fill ColorBits in Video buffer and math more.
    USE.
    Long to modify. xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    ······· ·BITsSET 10,5,10110 <Position,xBits,Bits
    Long After······· xxxxxxxxxxxxxxxxxxxxxx10110xxxxx
    Ps. Maybe Modify Long after that instruction
    Ps2. Even deriviates AND, OR
    Sapieha
    Post Edited (Sapieha) : 9/4/2008 8:32:13 AM GMT
  • simonlsimonl Posts: 866
    edited 2008-09-04 00:24
    Beau said...
    Cheers,
    Simon
    www.norfolkhelicopterclub.com
    You'll always have as many take-offs as landings, the trick is to be sure you can take-off again wink.gif
    BTW: I type as I'm thinking, so please don't take any offence at my writing style smile.gif
    edited 2008-09-04 05:00
    This is very exciting. [noparse]:)[/noparse]
    The PropII seems so close yet so far from our hands.
    edited 2008-09-04 08:48
    Hi Beau Schwabe.
    I am curious what funktions is planed in CPU/ALU block
    I shortage to·me is INC/DEC COG register one step and mayby x steps for use with Address advance.
    Ps. And any·type of register software counters
    Sapieha
    Post Edited (Sapieha) : 9/5/2008 3:22:40 AM GMT
    edited 2008-09-04 09:47
    So should we expect a PropI-64 IO some time in the future as well as PropII or is the idea shelved ? Giving us a 3 chip Prop family ..
    John Twomey
    edited 2008-09-04 10:52
    Hi Chip Gracey.
    My next question on counters is.
    If·You can reconstruct them to have UPP/DOWN capablites with 2 PIN control.
    4 counters (X,Y,Z,A) on COG. Very useful in all Robot control.
    Sapieha
    Post Edited (Sapieha) : 9/4/2008 11:03:36 AM GMT
