"Labor" (on Propeller) "Day"
Oldbitcollector (Jeff)
Ok Gang, it's a holiday again!
If you're like me you've been in a hustle to get all those chores
done to keep Labor Day open for Hotdogs and Propellers.
(Is there time for a Propeller-based hotdog rotator?)
What Projects are you planning to work on on Labor Day.
Common gang, set some goals here.. [noparse]:)[/noparse]
I'm going to work on my PPDB instructional/code for beginners.
(Because I can totally relate, being I'm only 15min ahead of them.)
Anyone else?
OBC
New to the Propeller?
Getting started with a Propeller Protoboard?
Check out: Introduction to the Proboard & Propeller Cookbook 1.4
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card connected? - PropDOS
Anyone else?
OBC
--Steve
God Bless!
I've had all the parts laying around here for awhile, I decided this weekend I was going to finally get my CNC lathe fitted with its Propeller powered tool changer. I have already most of the code in objects and just need to wire everything up and polish up the code and I hope it works!
Thank's Brian
·"Imagination is more important than knowledge..." ·· Albert Einstein
www.PropelX.com
Mark
I am 1011, so be surprised!
Advertisement sponsored by dfletch:
Come and join us on the Propeller IRC channel for fast and easy help!
Channel: #propeller
Server: irc.freenode.net or freenode.net
If you don't want to bother installing an IRC client, use Mibbit. www.mibbit.com
I'll play with my SD Card Adapter, PropDOS and continue on the Prop Education Labs.
Whit+
Jesse
W5JCD
so i'll be putting that together and running it in.
also have used diptrace to create a pcb for my sd card sockets..
will try to mill that for fun
heres a pic of my new mill.... 4' x 4'
Oh wait a minute, it's not a holiday here in Finland. You'll have to wait for Chip to get back.
·- Ouch, thats not suppose to be hot!··
Michael King
Application Engineer
R&D
Digital Technology Group
······················· P.S.don't forget to check the _born on date_!!!!!!!!!!!!!!_%WMc$_out!!!!
Cheers,
Simon
www.norfolkhelicopterclub.com
You'll always have as many take-offs as landings, the trick is to be sure you can take-off again
BTW: I type as I'm thinking, so please don't take any offence at my writing style
Well, my fun plans kinda fell through. Our power was on and off a good bit. We are in Northeast Louisiana and still got pretty good winds and rain (which is still going on) from Gustav. All in all, things were not really as bad as they could have been in the southern part of the state. We have lots of evacuees up here, which is great because most folks were smart enough to leave south Louisiana.
Did get to read some by battery powered lantern!
Whit+
