LM34 Fluctuation
I am taking readings from a LM34 through an ADC. I am experiencing fluctuation readings of up to 6 degrees(jumping around).
I even added a 75 ohm resistor an 1uF cap no real difference.
What may be the reason be for this?
For in much wisdom is much grief, and he who increases knowledge increases sorrow." ~Ecclesiastes 1:18
Fluctuation on the lm34 occurs on and of (away from the engine). The LM34 is also mounted on the pc board and not on wires.
'Still some PropSTICK Kit bare PCBs left!
