GEAR
hi guys,
I cant get GEAR to work. whenever i go to http://soft.java-virtual-machine.net/virtual-machines/gear-parallax-propeller-debugger.html it comes up with the message "Fatal error: Cannot redeclare ExCaching::$conclusion in /home/javayvi/public_html/soft/modules/excaching.class.php on line 32"··
Bryan
Bryan
GEAR is C# using·.NET not JAVA. You can download·GEAR from here http://forums.parallax.com/showthread.php?p=701256.
Pull my finger!
My only question - straight off the cuff - are you trying to run GEAR in Linux which is then calling that web page?
Clue #1: Vista machines may get this, and for C++ applications a possible work-around is to statically link the library files. However, GEAR isn't C++, so the option is not available in the compiler. http://forums.msdn.microsoft.com/en-US/vcgeneral/thread/936daccb-57cf-4934-94dc-9540e0bb2800
Clue #2: There may some service that interfering with the startup procedure - maybe for the first time only. http://blogs.msdn.com/astebner/archive/2006/05/17/workaround-for-possible-timing-issue-that-can-cause-net-framework-setup-failures.aspx
Other than that, I'm not sure that I can help. This is the first time this particular·problem has been mentioned, so is it possible that your .NET installation is corrupt?
