What the well-dressed PPDB is wearing this fall...
Oldbitcollector (Jeff)
After everything that Ken donated to the Expo, he was also gracious to give me a PPDB!
(Parallax is the very definition of "awesome" -- Thanks Ken)
I couldn't bear the thought of my shiny new PPDB sitting on the workbench collecting particles
of dust when not in play.. I like the idea of the PEkit case and thought it work here too.
A little time with the rotary tool and.....
(I ordered mine from here...
theezcatalog.com/index.aspx?StId=158&ShId=5e09bb88334f41c083c615b2470e6a06&tab=13&Qtype=1&sku=626155)
New to the Propeller?
Getting started with a Propeller Protoboard?
Check out: Introduction to the Proboard & Propeller Cookbook 1.4
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card connected? - PropDOS
PPDB fine but to expensive to My pocket.
Sapieha
Post Edited (Sapieha) : 8/31/2008 9:33:16 PM GMT
Like it..
Pull my finger!
(that is, once I get another shipment of them in later this week)
Brian
uController.com - home of SpinStudio - the modular Development system for the Propeller
PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
I am 1011, so be surprised!
Advertisement sponsored by dfletch:
Come and join us on the Propeller IRC channel for fast and easy help!
Channel: #propeller
Server: irc.freenode.net or freenode.net
If you don't want to bother installing an IRC client, use Mibbit. www.mibbit.com
Timothy D. Swieter, E.I.
www.brilldea.com·- Prop Blade, LED Painter, RGB LEDs, uOLED-IOC, eProto fo SunSPOT, BitScope
www.sxmicro.com - a blog·exploring the SX micro
www.tdswieter.com
(In the bag..)
OBC
Anyway, I had a similar item in mind while twiddling my thumbs Saturday and ordered a Plano 1119-06 double sided tackle box.
It's 13.5 x 10.2 x 4.5 with a 10 x 5.3 x 2.25 compartment on one side, which will nicely accommodate the PPDB, while allowing ports for all of the left hand side services to be accessible through the case (dremeled to suit). They can be had for less than $20
on Amazon or local outdoor supply houses. I'll upload some photos once I fit it all out.
Great minds think alike!
Not only were my measurements incorrect, but the beautiful green, plastic covers on these boxes collect and retain static electricity like a cat's fur!
Thought it would be a good idea, but unless you have a need for a fishing tackle box or something to hold non-static sensitive parts in, try something else. My apologies if any of you have already sent off for one of these.
Post Edited (liljoentx) : 9/9/2008 4:54:26 PM GMT
I guess you've made your case.
Sorry, couldn't resist...
I have been using this Plano Model 3750 from back when I started for my Board of Education and parts, shown here on Amazon - http://www.amazon.com/Plano-3750-Prolatch-Inhibitor-Chips/dp/B000E39T5A. I was surprised when I got my PE Kit and Parallax had used the same box.
I made another one for my Propeller Proto Boards and parts. I also stole Parallax's idea and made an insert card for the lid with the dimensioned drawing of the Proto Board and the Proto Board Schematic on the inside.
Whit+
Post Edited (Whit) : 9/2/2008 1:58:09 PM GMT
