My First Bot
Oldbitcollector (Jeff)
This is truly a first for me...
While I'm waiting for some more stuff for my mini HERO project,
I thought I'd dive in a get my feet wet.
This is the result after night 1..
The base is a piece of ABS plastic I cut from the top of an old Gateway case.
OBC
New to the Propeller?
Getting started with the Protoboard? - Propeller Cookbook 1.4
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card? - PropDOS
Need a part? Got spare electronics? - The Electronics Exchange
OBC
BTW, if you're in a hurry to get your bot's rear end off the ground, consider a drawer pull at least temporarily, as the CBA robot uses. Quick & dirty, looks good, probably just as good as a real caster if you don't put too much weight on it.
http://www.budgetbot.com/CBA_Kit.html
Got the third swivel wheel on, and started to run into challenges...
First challenge.. Learn that servos require different pulse rates to go different directions.
(That had me going for a few minutes..)
Second, had problems with the servo section of the Propeller board.. Recreated
another servo connection point by running 5V straight to it, instead of going through
the cap near the original servo connections. Not sure if I shorted that section out
when I assembled it (The tolerances are pretty tight), but either way, I got it functioning.
Next challenge.. Why does my prop reboot when I attempt to run both servos at once?
Perhaps I'm drawing too much power?
Here's a shot of today's progress..
OBC
Homemade Boe Bot now moves forward correctly!
OBC
Working perfectly now thanks to a little debugging... (and help from Mike Green)
Not bad for a robot made out of two Parallax servos, a Protoboard, and uController SD adapter..
Most everything else was recycled materials. (Except the $2.00 caster wheel.)
Edit:
I swear I've never built anything mechanical that actually worked! Thanks Parallax!
Next problem: I can't bring myself to tear it apart for parts for my HERO1 project.
(I swear I actually saw a tear fall out of a servo when I moved toward it with a screwdriver. [noparse]:)[/noparse]
Time to order some more servos!
OBC
Post Edited (Oldbitcollector) : 6/2/2008 3:47:29 PM GMT
Whit+
