filter for zero crossing determination
Hi crew, need some help
Here is the problem: I am trying to come up with a solution on a prop to reliably determine zero crossings in various vr-sensors' signal. (has to be compatible with different models/makes of vr sensors)
In practice, there may be quite a bit of noise picked up by the signal wire, which could result in 'fake' zero crossings which absolutely must be filtered out (as some critical operations depends on those zero crossings).
As the vr-sensor reads motions of a large mass mechanical device, the transients shouldn't be that great (perhaps that would help with separating noise from real signal). The signal itself is in the range of 500 to 20,000 HZ
I'm only starting to learn about signal processing and applying it in practice, so please take it easy on me and any help in that direction is welcome.
Thank you
Thank you
'Still some PropSTICK Kit bare PCBs left!
Comparator with hysteresis has been tried and still led to fake zero crossings. Besides, i would like to create a system that would be able to adjust itself to different 'flavors' of vr signal. Consider that noise amplitude (the dangerous 'fake' spikes) can be same as the real signal amplitude.
I understand about the delay and would be fine with 1 or 2 periods of it (but 1 is better as the system is very realtime in nature).
·- Ouch, thats not suppose to be hot!··
Michael King
Application Engineer
R&D
Digital Technology Group
-Mike
-Mike
Edit: disregard - I failed to thoroughly read your earlier message!
1: Keep it clean.
2: Model it and predict.
3: Filter it.
Getting number one sorted is by far the most important. On that note: What is this sensor? Non-contact is best. How is it wired? Is there local buffering and conditioning at the sensor? Is the cable shielded? Are ground loops possible?
Evan
-Mike
