NTSC from VGA Refresh rate problems?
I'm new to the Prop.(Old school Basic), I have·Modified the Example Prog. " FrequencyCountv1.0"; I change the OBJ. file from "txt_vga" to " txt_tv", This worked but the refresh rate is to slow and the display "flickers" real bad.,How can I correct this w/o a hole lot of code????
