Did I break some Forum Rules -- or ask too many Questions?
·I noticed that my questions went unanswered. And also the person in front of me and behind me got answered quickly.· Is it possible that I have offended someone?· I thought that this was the place to ASK questions about the propeller.· Most people have been very nice to me. I think that this forum holds a LOT of knowledge.· I was told, after I read all the documentation and I don't understand, then ask a question. That what I have done.
BTW, my little boebot is doing just fine. But, I will FOREVER improve upon it.
If I have offened someone by asking what you might feel is a STUPID question, you have my apologies.· I used to teach for 12.5 years. In my class, there was no "Stupid Question"·. I figured that I would ask because you never know, someone else might have the same question.·
I am not an Engineer, but I did hold down an Engineer's job once for 9 years.· But, my hat goes off to you Engineers. You are smart. But, I am curious. Some times i feel like I shouldn't ask so many questions.
Hope this doesn't rub someone the wrong way. I like this community very much.
I don't believe you offended anyone ..·Here the·forum·members are not like that. There has been a lot going on on the forums lately re: recent expo,C discussion and Prop2 starting with a clean slate.I believe it's best to ask pretty specific questions and give as much detail as possible when posting - then you are more likely to get meaningful responses.
Don't loose heart..
John Twomey
'Necessity is the mother of invention'
Those who can, do.Those who can’t, teach.
Post Edited (QuattroRS4) : 8/28/2008 10:20:18 PM GMT
Paul Baker
·- Ouch, thats not suppose to be hot!··
Michael King
Application Engineer
R&D
Digital Technology Group
Most of us don't have the technical and tutoring skills to answer every question that comes along. Many times, when I encounter a beginner's question, I pass on it because, frankly, I just don't know where to begin. And I know that, once I weigh in, I'm committed to sticking with it until some satisfaction is obtained or someone else more knowledgeable (or patient) jumps into the fray. And that often scares me off, unless it's a subject near and dear to my own interests. Except for Parallax's tech support team, we're all volunteers here, which means we get to pick and choose which questions to answer, as time permits. Not getting a question answered should never be taken as a slight but, rather, just a a sign that it didn't resonate with someone's particular interest or ability to contribute something useful. Anytime you don't get an answer to a question, simply rephrasing it or adding specificity and examples of what you've tried can often break the logjam of silence.
'Still some PropSTICK Kit bare PCBs left!
Post Edited (Phil Pilgrim (PhiPi)) : 8/28/2008 10:26:41 PM GMT
If you don't ask and explore you won't learn...
I'd encourage you to keep make your questions specific as possible,
providing as much information as you can about your setup, what
you've tried, and code. Remember we can't see your configuration
from here. [noparse]:)[/noparse]
Also try to hold a topic in a specific thread. It helps the rest of
us old guys keep track of the conversation. [noparse]:)[/noparse]
BTW, Keep an eye on your mailbox in the next 2-3 days...
OBC
New to the Propeller?
Getting started with a Propeller Protoboard?
Check out: Introduction to the Proboard & Propeller Cookbook 1.4
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card connected? - PropDOS
Post Edited (Oldbitcollector) : 8/28/2008 10:23:11 PM GMT
Patience is a valuable commodity. Take a deep breath. If it's nice weather outside,
go enjoy the late summer. Spend some time with your family or friends. Do check
the forums occasionally. Perhaps you will feel even better when you come restored
back to a cheery, helpful suggestion that you now appreciate even more now that
you've been doing something else for a little while.
I know it’s easy to take it personally when you post a question and you wait eagerly for someone to answer it...only to watch as others get answered when you know someone who has seen your question could EASILY answer it, I truly understand and have been there before.
I'm sure you have not offended anyone and I hope you have not been offended.
Just try to re-post it with some more info...or add some more info as you keep working on your issue.
In this regard people can see the direction you’re heading in I think.
This IS the place to learn a ton about the prop etc. So DO keep posting your questions.
Rick
Another thing that happens is you are there playing catch with the dog, talking with friends, whatever and it hits you! Often some stupid problem can be factored away, if a different solution path is taken. This is often difficult to consider when you are in the heat of the problem.
Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
I am on my way on the boebot. Just gotta finish up some programs.
God Bless You all!
just take your time.
understand how the code your using works.
boebot basic is a fairly complicated system, pretty soon your going to reach the end of mikes preinstalled objects, then when you go out on your own, it will be pretty hard.
the prop tool has the ability to open several spin programs.
for example , open boebotbasic.spin, then open the mass storgae object thats written in spin, and the deffintion object.
now using the tabs at the top, you can follow mikes code out for the sd card driver ( thats what i did earlier today )
you have to page back and forth to see whats happening..
i dont mean that you have to read every line of code, but you need to have a idea whats happening, so you can extend it when you reach the endpoint..
dont forget to document your additions either [noparse]:)[/noparse]
that way i can understand it.
dan
Chris Savage
Parallax Engineering
