srf04sonic sensor
please could some one help me iam new to robotics and electronics ,
i need help with wirind coding so i can get my boe-bot roaming with the srf04 sensor
········· please please help
······ james parks
······ james parks
- Stephen
Chris Savage
Parallax Engineering
There is readily available documentation for this product and the interface with the BS2 from the following web site. There is not a header on the module like there is the PING)));·so you will have to solder the connections on the module to the board as well.
You can download the manual with the link below that has sample code also.
http://www.acroname.com/robotics/parts/R93-SRF04p.pdf
I hope this help
Joshua Donelson
www.parallax.com
kind regards james
- Stephen
