Multi Cog Tile Driver Tutorial...
Howdy...
Been working on this for a while and learned a lot about making video drivers and tile drivers...
This driver supports 8x8 tiles with smooth scrolling and overlaying sprites at a resolution of 376x240 pixels in NTSC.
The code was written to be easy to understand and the tutorial explain things a little bit more in details.
Even though the driver can be used as is, feel free to use it as a template for your own projects.
By the way, it's a good idea to first go through my NTSC tutorial,
http://forums.parallax.com/forums/default.aspx?f=33&m=277812
Just to get a background on the NTSC driver since it's not explained in this tutorial.
Thanks to everybody who helped out and special thanks to J.T. Cook and Baggers...
Living on the planet Earth might be expensive but it includes a free trip around the sun every year...
Experience level:
[noparse][[/noparse] ] Let's connect the motor to pin 1, it's a 6V motor so it should be fine.
[noparse][[/noparse] ] OK, I got my resistors hooked up with the LEDs.
[noparse][[/noparse]X] I got the Motor hooked up with the H-bridge and the 555 is supplying the PWM.
[noparse][[/noparse] ] Now, if I can only program the BOE-BOT to interface with he Flux Capacitor.
[noparse][[/noparse] ] I dream in SX28 assembler...
/Bamse
Post Edited (Bamse) : 8/27/2008 3:49:43 PM GMT
Experience level:
/Bamse
I had to use 5 render cogs to be able to have the three sprites in the "demo" work on the same line...
That made the total of cogs 7 just to run the demo...
However it was written as a tutorial and there are a lot of things you can do to improve performance...
Lower the resolution for example, a lot of pixels are drawn outside of the visible area...
Experience level:
/Bamse
I was working on tile/sprite driver that had 8 16x16 sprites per line(no screen cropping, no scrolling yet), 256 verticle pixels and I used 4 COGs. My goal was to release that, with a simple windows app to draw sprites and tiles. When I get some time, I need to finish that up sometime and release it. The goal was to make an easy to use graphics system.
I've finally had the time to take a look at your tutorials. A lot of this sort of work was a grey area for me before; I understood the concepts behind it but not really any of the specifics. Reading your tutorials, within a few minutes of reading things really start to make sense and I can understand about how to translate those conecpts into real working code. It's a good feeling to have.
I think I want to re-write a lot of the code to work on a smaller resolution and optimize the code to make it more useful.
It's probably a good idea to use a more generic Raster driver to make it work on PAL as well.
One thing that should speed things up is to have a few tiles in the cog itself since you don't have to access the shared memory for these...
@Spork Frog,
That's pretty much why I wrote this tutorial as well, to learn ho to do this...
I have learned a lot by writing it and I'm glad others have use for it as well...
Experience level:
/Bamse
