Electronically controled valve in a valvetrain with power solenoids"it´s possib
I have in my mind one system to control the valves in "explosion engines" like a v8 engines or other , to control the pull· up and pull down of valve train.
this is aplicable to be more·income of engine·,and economy
Thank you
Thank you
In theory this work, but i never tested in real planes of this matherial word.
Thankyou , send me email if have interest in this.
There is a massive (relatively) inertia to be accurately controlled at very high speed in ferocious environments.. I'd suggest the mechanical portion of the task to be incredibly trying.
Pull my finger!
http://paultan.org/archives/2005/07/14/camless-solenoid-valve-engines/
http://www.italiaspeed.com/2005/cars/other/technology/02/05_02.html
the 2008 Mercedes C class uses the KDI EVT engine ..
Apparently many have examples of Solenoid valves replacing the inlet valves ... more complicated replacing the exhaust valves.. Apparently·varying versions of full EVT(electronic valve train) engines are in development·worldwide ..Fiat,Mercedes and GM to name a few..
John
'Necessity is the mother of invention'
Post Edited (QuattroRS4) : 8/21/2008 12:15:47 PM GMT
Maybe in modern sports engines there is an electric motor to adjust the lead/lag of the valves? Is this the sort of adjustment you are after?
Evan
Evan
this is not ideal for use in race cars , but for economy and options of performance in esportive cars
the control of valve "time if the valve is opened or exaust valve controled "more economy of combustible at more rpm of engine need to run with low gasoline and oxygen or other combustible .
Sorry about my english
Apparently there is a marked improvement in torque using an EVT setup v Standard valvetrain on otherwise identical engines.
Diesel engines took a massive leap forward once variable valve timing technology was perfected .. Are we due further enhancements once EVT for diesel is available ?.. due to higher compression of diesel engines I am sure this will further add to the exhaust valve headaches ... I think many prototypes will bend conrods !
I think this thread should be 'Sandboxed' ..
John Twomey
look my musics and aboutme
www.mymusicstream.com/member/9015
I've thought about that a _lot_.. having bent a rod or two previously.
If the device is electromechanically actuated, then the holding and positioning force of the actuator needs to be stronger than the conrod to bend it.
I do however envision dented pistons and bent valve rims [noparse]:)[/noparse] (and yes, I've done that too)..
Pull my finger!
HELLO for all
hydraulic or solenoid?
Picture an engine doing 13,000 RPM.. now those little valves are rocketing open and closed about 100 times per second. That's a hell of a lof of force to be throwing around. Plus you are not just opening and closing them. To get maximum flow you need to be following the piston up and down, so you need to very accurately position the valve. (Why is cam profile so important?)
As Uncle Arthur always said.. remember kiddies, there are some things in life that are not meant to bounce. Valves are one of them..
Nice academic conversation though..
Pull my finger!
rbowes1.11net.com/dbowes/
That guy is probably the most advanced in this field, on a hobby level.
Also, this has been discussed at length in another post:
http://forums.parallax.com/showthread.php?p=735134
Check that out for more info. This is possible, but will require lots of resources.
-Parsko
Evan
Graham
Graham Stabler.
