1$ part is stopping my project!!
I reallllly need help here!! i want to get more I/O from my bs2, but none in my area stocks a 74hc595.. i need to know if there is an equiv. part?? all the stores around here supply nte semis.. the nte part i keep coming up with is nte2053 does anyone know if this will work?? and can i cascade it like the 74hc595?? got the day off and want to get my project moving but this 1 part is between me and my beloved stamp!!!1
http://www.microchip.com/wwwproducts/Devices.aspx?dDocName=en010412
ok made it easier for you - n&v article is - http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/vol5/col/nv109.pdf
J
Post Edited (Javalin) : 8/15/2008 11:57:37 AM GMT
I am in Taiwan and can locally buy the 74HC595.
Mouser has it in stock and pretty reasonable about small orders.
It's sunny and warm here. It is always sunny and warm here.... (unless a typhoon blows through).
Tropically, G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
oh well thanks to all those who made suggestions..
Also, the '595 is actually a combination of two parts that you may already have:
1. 8-bit serial-in-parallel-out shift register (74xx164).
2. 8-bit clocked register (74xx374) or transparent latch (74xx373).
I'm sure there are other ways to do what you want with what you have or what's available nearby...
'Still some PropSTICK Kit bare PCBs left!
Chris Savage
Parallax Tech Support
I'm almost sure I have seen that done before. Just put all the latches in series and feed the first one.
If you have a big enough assortment of chips there might be other ways.
For example, a counter plus an 8-bit addressable latch. (4020/4024/4040/4060 + 4099/74HC259)
