1$ part is stopping my project!! — Parallax Forums
NR1XNR1X Posts: 111
edited 2008-08-21 03:44 in General Discussion
I reallllly need help here!! i want to get more I/O from my bs2, but none in my area stocks a 74hc595.. i need to know if there is an equiv. part?? all the stores around here supply nte semis.. the nte part i keep coming up with is nte2053 does anyone know if this will work?? and can i cascade it like the 74hc595?? got the day off and want to get my project moving but this 1 part is between me and my beloved stamp!!!1
  • JavalinJavalin Posts: 892
    edited 2008-08-15 11:52
    A Similar part is the Microchip mcp23016 which is a sixteen·pin I/O expander.· Its i2c rather than serial but look at in the parallax website on the downloads - and there is a nuts&volts with explaination and example code for it.
    http://www.microchip.com/wwwproducts/Devices.aspx?dDocName=en010412
    ok made it easier for you - n&v article is - http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/vol5/col/nv109.pdf
    J
    Post Edited (Javalin) : 8/15/2008 11:57:37 AM GMT
  • NR1XNR1X Posts: 111
    edited 2008-08-15 12:02
    this would be a great alternative but noone around here has it... was hoping to pick somethin up today...
    edited 2008-08-15 12:05
    The NTE2053 is a CMOS 8−bit successive approximation Analog to Digital converter.
    edited 2008-08-15 14:22
    Where exactly are you located?
    I am in Taiwan and can locally buy the 74HC595.
    Mouser has it in stock and pretty reasonable about small orders.
    It's sunny and warm here. It is always sunny and warm here.... (unless a typhoon blows through).
    Tropically, G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
    edited 2008-08-15 15:17
    im in ct, usa.. guess ill order a fistfull of the 74hc595s, nte seems to be pretty much useless... stinks that everytime i start a project i have to shelf it because i have to wait for parts!! well probably add this to the list of things that never gets finnished.
    oh well thanks to all those who made suggestions..
    edited 2008-08-15 15:52
    The 74xx4094 and CD4094 are work-alike (but not pin-compatible) substitutes for the 74xx595. The output drive of the CD4094 is much lower, though.
    Also, the '595 is actually a combination of two parts that you may already have:
    1. 8-bit serial-in-parallel-out shift register (74xx164).
    2. 8-bit clocked register (74xx374) or transparent latch (74xx373).
    I'm sure there are other ways to do what you want with what you have or what's available nearby...
    'Still some PropSTICK Kit bare PCBs left!
    edited 2008-08-15 17:57
    Thanx Phil, im goin through my pile of stuff now. doesn't look like theres any 4094s here. got this box of ics given to me at the end of a hamfest most of it i have no idea but theres alot of opamps counters flipflops and even a few bcd to 7 seg. decoders.. these things are all in ecg boxes and some in little baggies from rca.. i think its all pretty old stuff but i bet it all works fine.. even found a few optoisolators with darlington array.. pretty cool what you find in some boxes at a hamfest!!
    edited 2008-08-15 19:31
    The cross for NTE for the parts Phil mentioned (at least in the LS family) are just NTE74LS164 and NTE74LS374, just in case it helps.
    edited 2008-08-15 19:58
    thank you , im just gonna order the parts and wait. i hope i can remain patiant!! the local places arent that local anyways (1hr drive min) so now to pick some other toys to play with. its kinna stupid to order just a couple of shift registers.. maybe an oem bs2 kit,or a pir sensor or even an lcd display!!!!!! lotsa new things to try
  • VIRANDVIRAND Posts: 656
    edited 2008-08-21 03:38
    BTW, Isn't it possible to make a shift register out of a 74HC373/374/573/574 ? (573/574 have nice pin order).
    I'm almost sure I have seen that done before. Just put all the latches in series and feed the first one.
    If you have a big enough assortment of chips there might be other ways.
    For example, a counter plus an 8-bit addressable latch. (4020/4024/4040/4060 + 4099/74HC259)
    Interesting point! The '74 parts would work this way; not the '73s, though.
