ETA on propeller development board
Not sure on the exact name of it, but I was wondering if there is an ETA on the development board (the larger one with a breadboard and other things around the outside of it) for the propeller. I received the email from parallax about it a little while ago, but I accidentally deleted that message.
Matt
Matt
From the vague description ('the larger one' and 'a little while ago') might you be referring to the ProtoBoard? Check out this link
www.parallax.com/Store/Microcontrollers/PropellerDevelopmentBoards/tabid/514/CategoryID/73/List/0/Level/a/ProductID/423/Default.aspx?SortField=ProductName%2cProductName
Hope this helps...
Harley Shanko
Brian
uController.com - home of SpinStudio
PropNIC - Add ethernet ability to your Propeller!
SD card Adapter
Paul Baker
Nice catalog, Parallax. And nice prototyping board.
Harley Shanko
We’re pretty close to having these manufactured. Many of the IC packages are QFN and we are taking steps to prevent manufacturing issues related to these packages. Once we’re past that point we should start getting some within 6-8 weeks. Take care.
Chris Savage
Parallax Tech Support
Chris Savage
lead to greater interest and thus higher sales......
Hope they end up being in the sub $100 range so I can afford to have a few laying around for quick circuit hook ups. The Demo board is ok for quick simple projects but having the extra features and larger 'real estate' would be handy. Proto Boards are handy for one off permanent circuits.
So with the Propeller, I'd figure it will be more expensive, but still I'm sure quite worth it based upon what is included.
Further speculation I shall leave to a Parallax Employee.....
Brian
uController.com - home of SpinStudio - the modular Development system for the Propeller
PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
The Propeller Professional Development Board (PPDB)·is a high-quality, fully-integrated development platform for the Propeller microcontroller.· A wide variety of typical I/O (LEDs, Buttons, etc.) devices and circuitry are built into the PPDB, providing the developer with an ideal platform for rapid Propeller project development.
For more information, or to purchase the board (#32111), visit http://www.parallax.com/tabid/134/List/1/ProductID/515/Default.aspx·.
Chris Savage
I guess there was no room for an SD socket? That would have been sweet.
And of course 32K rather than 64K EEPROM; probably the 64K parts were too pricey?
In any case, this is immediately going on my wish list, and we'll talk with Susie Q tonight.
Is there any chance Parallax can sell me some additional hours in the day? *That's*
what I really need.
"... breadboard it I a good idea ... ": I -> is
bus/buss; both are used as the singular of busses; either is fine, but both is inconsistent.
I prefer bus.
Connection Diagrams are (as yet) missing.
I like it though. We need someone to write some code that lights this thing up like a
Christmas tree.
Does the schematic permit connection of one of the pots to act as a volume control
for the audio amplifier? The pots are probably linear, which is less than optimal for
volume control, but better than nothing.
Been nice if they could have sub-$100 this product, but understandably priced!
Way to go Parallax.. yup.. going on my wishlist too..
May have to buy one and incorporate it into my book in the works.
There's justification for purchase!
OBC
New to the Propeller?
Getting started with a Propeller Protoboard?
Check out: Introduction to the Proboard & Propeller Cookbook 1.4
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card connected? - PropDOS
Timothy D. Swieter, E.I.
www.brilldea.com·- Prop Blade, LED Painter, RGB LEDs, uOLED-IOC, eProto fo SunSPOT, BitScope
www.sxmicro.com - a blog·exploring the SX micro
www.tdswieter.com
To those who yearned for an SD socket: Perceived deficiences (glass half empty) can also be looked at as opportunities (glass half full). There are plenty of holes available to plug in an SD socket daughterboard!
'Still some PropSTICK Kit bare PCBs left!
Why are the DIP switches and the push buttons active-low? This seems bizzare to me - surely the convention is active-high?
Otherwise i'd probably have bought one...!
James
-Parsko
@Parallax: Any chance we could get Paul to bring a few of these with him to the Expo for sale?
(If I order it today, it will arrive at about the same time.)
Either way, one of these will be on my desk very soon... [noparse]:)[/noparse]
OBC
@rokicki
Yes 32K is standard, but the 64K EEPROM is socket compatible if you should desire to use it in place of the stock 32K unit. Price wasn’t so much an issue as availability (long term) for DIP (through hole) EEPROMs. 24LC256 are more common and widely available. Busses can be set up any way you want. You don’t have to follow any convention on the breadboards. Which connection diagrams are you referring to? Schematics are linked on the product page for download, as well as documentation. The potentiometers were not intended for use as a volume control, but could technically be used if needed. You would have to use one for each channel in that sense.
@rokicki, Oldbitcollector, Rsadeika
When we were testing and developing with the SD Card Readers we obtained units from Sparkfun which had a SIP header and were able to connect them right into the breadboard no problem. SD Card Readers have a mechanical component to them. It seemed better to connect it to the breadboard. The units we have used are very small and take up little real-estate on the breadboard.
@SRLM
Yes, the EEPROM and L293D are in a socket and can be removed/replaced as needed.
@Javalin
Actually the more common connection (in my experience) is active-low on push-button inputs. I think this started with the fact that many electronic chips/circuits use active low schemes for such inputs as /RESET, /CS, etc. Devices controlling these circuits can often sink more current than they can source allow more inputs to be driven and more immunity to noise. Noise immunity is especially important in mechanical switches and allows compatibility with open-source/open-collector circuits on the same net.
@Parsko
Putting a Propeller on-board is just one step toward including cables, power supply, etc. At this point you have a kit rather than a board. I think most customers who will purchase the board will have everything else already. They are already developing with DIP Propeller chips, which mean they also have power supply and USB cables. This keeps cost down for everyone.
@Everyone
A lot of time and changes went into this board over time. It is our sincerest hope that Propeller Developers find it useful tool for their bench. We of course welcome and value customer comments even when they don’t necessarily lead to a change in a product. Take care everyone!
Chris Savage
Thanks for the reply. Perhaps an option for version 1.1 would be a SPDT switch to control pullup-pulldown then we'd have the options!
Cheers,
James
Paul Baker
Post Edited (Paul Baker (Parallax)) : 8/19/2008 3:48:18 PM GMT
of the bottom of this unit? I'm thinking that if this is like most Parallax stuff, we
can access the soldered connections underneath for mods.
Can someone at Parallax verify this?
OBC
Paul Baker
These are the four "mystery" items that I mentioned in the Expo thread. [noparse]:)[/noparse]
Thanks Ken!
OBC
