2.1 mm center-positive plug
Hey Everyone,
Does anyone have a good source (and part numbers)·on both the male and female 2.1 mm center-positive barrel power connector that is standard on Parallax Boards and Power Supplies? Secondly, are the lengths standard or do they vary?
Whit+
Whit+
I get the male board-mounted·part from Digikey.· Their part number is·SC1313-ND.· The female parts are usually corded like on the end of a power supply cord.· I you're looking for the connector on a cord, I usually get these from MCM: http://www.mcmelectronics.com/product/24-5360.· It's two for the price of one if you cut off the male end.·
Chris I.
Brian
uController.com - home of SpinStudio - the modular Development system for the Propeller
PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
Whit+
www.mouser.com/catalog/635/1090.pdf
- Rick
