Ping and the elements.
So I started to think about this and I’ve got to be over thinking it. Is there a good way to encase/ protect a ping or other ultrasonic range sensor from the outdoor elements? I can’t image rain/ snow ect would treat these things very well, but I can’t seem to think of a material to cover/ protect it with that ultrasonic could travel through.
The issue is I need the arc created by the ultrasonic (area versus range) . I just looking to see if there is something/ anything in the way about 6 feet. ·So laser is out of the question. Maybe another range finding device?
Any thoughts or ideas?
·- Was it pin 11 or 26?· Hmmm....··I think the smell of smoke tells the whole story.· Must be 26.
Michael King
Application Engineer
R&D
Digital Technology Group
·I have been experimenting with the PIR sensor minus the dome and add a reflecting telescope with no glass lenses.· This works great and the range is over 100m.· I protect the optics with large format film (Kodak style)· exposed to light directly and then developed.· I place this over the end of the scope and it allows heat frequency of light through without too much lose in energy or diffaction of light.
Michael King
R&D
Edit.... Any way to see a staic object like a wall using the PIR sensor? That would encompass its entire field of vision?
Do you have any idea if it can withstand subfreezing temperatures?
It might be the Information Age but the Eon of Ignorance has yet to end.
We won't know that until we characterize the part. I really couldn't say for certain because I don't know what kind of physics issues could be introduced. I'm sure that ice freezing on the transducer would change the response characteristics, for example. Perhaps it will run fine in dry & cold, but not in any humidity.
We'll only know when we start to test our samples (pretty soon!).
Or if you need a tester, Ive got some abuse up my sleeve.
Ive got to be buying enough stuff to get in on some prototyping. :P *Need less projects*
Thanks for the heads up, Ill be waiting if not, it would be ideal for the application.
TJ
