tell me what I am doing wrong.
TC
I am using a MAX7219. I am trying to place a·decimal point with digit number 2. But instead, the display drops brightness, and locks digit 2. What am I missing.
We all make mistakes when we are young………That’s why paste is edible!
sensor CON 0 DATA_n CON 1 CLK CON 2 Load CON 3 decode CON 9 brite CON 10 scan CON 11 switch CON 12 test CON 15 max_dat VAR Word index VAR Nib temp VAR Nib nonZ VAR Bit dispVal VAR Word odd VAR index.BIT0 DP VAR index.BIT3 OUTS = 0 DIRS = $000E FOR index = 0 TO 7 LOOKUP index,[noparse][[/noparse]scan,2,brite,15,decode,$7,switch,1],max_dat SHIFTOUT DATA_n,CLK,MSBFIRST,[noparse][[/noparse]max_dat] IF odd = 0 THEN noLoad PULSOUT Load,1 NoLoad: NEXT Loop: GOSUB MaxDisplay COUNT sensor,2930,dispVal GOTO LOOP MaxDisplay: nonZ = 0 FOR index = 3 TO 1 GOSUB ADD_DP SHIFTOUT DATA_n,CLK,MSBFIRST,[noparse][[/noparse]index] temp = dispVal DIG (index-1) IF temp = 0 THEN skip1 nonZ = 1 skip1: IF nonZ = 1 OR temp <> 0 OR index <= 2 THEN skip2 temp = 15 skip2: SHIFTOUT DATA_n,CLK,MSBFIRST,[noparse][[/noparse]temp] PULSOUT Load,5 NEXT RETURN ADD_DP: IF index = 2 THEN ADD_DP1 RETURN ADD_DP1: DP = 1 RETURN
Please give a link to the dislplay that you are using
··Thanks for any·
Sam
What LED Display are you using can post a link to it
··Thanks for any·
Sam
The code for the Binary / Digital Clock uses the decimal points for the colons in the display. You should be able to see how I turn them on/off by simply setting a bit in the data sent out to the MAX7219. I hope this helps. Take care.
http://forums.parallax.com/showthread.php?p=552892
Chris Savage
Parallax Engineering
