Easy Easy SD card reader
Thought this came out well. I grabbed a SMD prototyping board from fry's (2 or 3 bucks) and took apart an old SD card reader I had. Used a heat gun to remove the card slot from the old card reader and resoldered on to the prototyping board.
Looked thru one of OBC's PDF's and noted which pins aren't necessary and just took them out of the card slot.
Heatgun melted the plastic a little but, but it works just fine. I also dremelled the edge of the board to be flush with the card slot.
Concentrate on understanding the problem, not applying the tool
OBC
New to the Propeller?
Getting started with a Propeller Protoboard?
Check out: Introduction to the Proboard & Propeller Cookbook 1.4
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card connected? - PropDOS
that have been mentioned on this board. It will save you a lot of aggravation.
His professional level SD adapter has served me well all year..
OBC
OBC
I removed the sd card slot from my wife's broken mp3 player and placed it on a through hole breadboard, doesn't look pretty but it works.
Brian's SD reader is a few dollars cheaper + I like Brian more than SparkFun.
I melted a chunk of my carpet with a heatgun, trying to fix my xbox. BGA... Ugh.
Good job with the SMD's. I need to make an SMD toaster oven.
excess capacitor lead soldered directly to socket pins
then bent carefully and trimmed. plugs right into
Demoboard sans pullup resisters. works great.
blake
"Can't sleep, clown will eat me."
Bart Simpson
