Easy Easy SD card reader — Parallax Forums
Nick McClickNick McClick Posts: 1,003
edited 2008-08-25 05:00 in Propeller 1
Thought this came out well. I grabbed a SMD prototyping board from fry's (2 or 3 bucks) and took apart an old SD card reader I had. Used a heat gun to remove the card slot from the old card reader and resoldered on to the prototyping board.
Looked thru one of OBC's PDF's and noted which pins aren't necessary and just took them out of the card slot.
Heatgun melted the plastic a little but, but it works just fine. I also dremelled the edge of the board to be flush with the card slot.
Concentrate on understanding the problem, not applying the tool
1172 x 996 - 101K
628 x 596 - 32K
  • RaymanRayman Posts: 16,461
    edited 2008-08-17 23:21
    Looks good!· I wish we had a Fry's here...· Maybe Digikey has a little board like that...
    edited 2008-08-17 23:25
    Nicely done! I tried to salvage one of those with a heat gun and melted it beyond usefulness.
    OBC
    New to the Propeller?
    Getting started with a Propeller Protoboard?
    Check out: Introduction to the Proboard & Propeller Cookbook 1.4
    Got an SD card connected? - PropDOS
  • jazzedjazzed Posts: 11,803
    edited 2008-08-17 23:58
    While we're at it .... here's my adapter. A 2G microSD in a mini-microSD adapter with part of an old wire-wrap socket and some SMT resistors all secured with hot glue. Not a new idea, but very workable.
    640 x 480 - 18K
    640 x 480 - 22K
  • rokickirokicki Posts: 1,000
    edited 2008-08-18 00:42
    These are all novel and cool, but for novices, I highly recommend the Sparkfun breakout or some equivalents
    that have been mentioned on this board. It will save you a lot of aggravation.
    edited 2008-08-18 00:52
    Personally, I'm a big fan of the one that Brian/uController.com has for sale..
    His professional level SD adapter has served me well all year..
    OBC
    edited 2008-08-18 00:55
    I think somebody said it will work without any resistors at all. Anybody tried this?
    edited 2008-08-18 00:56
    I've built several without resistors that worked fine..
    OBC
  • Matthew HayMatthew Hay Posts: 63
    edited 2008-08-18 03:25
    Well done, wished mine looked as nice.
    I removed the sd card slot from my wife's broken mp3 player and placed it on a through hole breadboard, doesn't look pretty but it works.
    785 x 395 - 149K
    779 x 393 - 122K
  • Nick McClickNick McClick Posts: 1,003
    edited 2008-08-18 04:10
    I tend to agree that it's easier to order than to jury rig, especially for beginners. I like messing around with hardware, though.
    Brian's SD reader is a few dollars cheaper + I like Brian more than SparkFun.
    I melted a chunk of my carpet with a heatgun, trying to fix my xbox. BGA... Ugh.
    Good job with the SMD's. I need to make an SMD toaster oven.
  • b.p.m.b.p.m. Posts: 59
    back to basics
    excess capacitor lead soldered directly to socket pins
    then bent carefully and trimmed. plugs right into
    Demoboard sans pullup resisters. works great.
    blake
    "Can't sleep, clown will eat me."
    Bart Simpson
    2576 x 1920 - 161K
    2576 x 1920 - 465K
