printing from SX IDE
When trying to print, I get a message "list index out of bounds (0)" message.· I am almost sure this was descussed in the past, but cannot retrieve it with the search function.· Any help is appreciated.
Chet
Post Edited By Moderator (Bean (Hitt Consulting)) : 8/10/2008 1:38:02 PM GMT
Chet
Regards
Chet
If I could reproduce your problem, I'd fix it. However, i just tried printing from the Beta version and it worked without any problems. If printing works on my machine, then I don't have any way to debug the problem since, on my machine, there is no problem. Perhaps some more details of you setup might help.
Regarding the ability to double click and open a file, that's a Windows issue. Programs under Windows do not handle opening files that are double clicked by themselves. Windows sees the double click, looks to see if there is a registered file type and an associated program, and then invokes the program with the file name on the command line. This is something that is setup at the time of program installation. If it isn't, then Parallax needs to update the installer. You can set file associations yourself. Here's a pre-made Google search to let you find a page that explains it best for you:
http://www.google.com/search?hl=en&q=windows+set+file+association&btnG=Google+Search
If your source files don't show the little SX-Key IDE logo (the crossed key and chip), then your file associations are not setup.
PeterM
Post Edited (PJMonty) : 8/8/2008 10:30:32 PM GMT
· Actually I had the same issue on 2 computers right now.· One a laptop running Windows XP, and the other a Desktop running Vista.· They are both using the same Xerox laser printer so Monday I will attempt to print from work.· I've had no issues printing from the older program.
Russ
Thanks for the feedback anyway. Neet to get back to figuring out other fun stuff .....
Have a good weekend.
Regards
Chet
