Propeller application: DS1620 demo (VGA output)
Beau Schwabe
This application uses the DS1620 in hi-res temperature mode and displays the results on a VGA monitor.
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 10/3/2006 2:19:45 AM GMT
Beau Schwabe
IC Layout Engineer
This is a pretty long preamble to a really simple question... if you like you can skip to the question at the bottom and give me a one word answer[noparse]:)[/noparse]
Intro: I've had the repeated experience that whatever the problem is between me and my Propeller... it is inevitably me and not my Propeller... assuming I haven't killed it.
Current History: I downloaded Jon's incredibly well structured and documented 1602 object and tried to mix it into my Public Domain-uOLED (96) project and I just couldn't get it to work... I have it hooked up OK... I mean... it is difficult to see how I could have screwed it up... it has 5 volts in, ground out, and I have to put a 1K resistor on the data i/o line and get the pin assignments for the clk and rst correct... and I've triple checked it all and I even put a .1uF capacitor in as suggested in the documentation, which is plentiful and easy to understand.
Following the theory that possibly my project had overgrown itself without throwing a warning (I know... not very likely but I was grasping at straws[noparse]:)[/noparse], I decided to simplify my life and start with your demo... strip out the VGA calls...and throw in the object for the 96 graphics. The only other thing I did was to use Jon's simple numbers object to do the decimal to string conversion so I could display returned values on my UOLED. I'll post it all ... just as soon as I get it working.
Right now, "IT" don't work at all... it compiles ok, but there is an initial call to set the hi limit to 85 degrees... and then a call to retrieve the value... it fails. (Returns a value of 0.) I checked all of the pins on the 96, they work. And I get a constant signal on the "HiLimit" and common pins of the 1602. I have tried a couple of 1602's so unless I have two bad chips from a bad batch( which you guys would know by now) I can believe that the chip is bad.
Is there some reason that your code won't work at 64MHz? (8MHz/pll8x) I looked at the possibility and don't see it.
Rich
Should work ok at 64MHz... I'll look at the code a little closer and see. I'm out of town this week, so internet access is limited, but I will look at it and try to get back to you.
Beau Schwabe
IC Layout Engineer
I'm sure glad you were out of town and didn't waste any time on this...
Thanks Jesus!!!
Perhaps we should dig out that thread on really dumb things done
with a Propeller.. (Like my cutting of board traces why attempting to
quickly resolve a solder bridge at 2am.)
New to the Propeller?
Getting started with a Propeller Protoboard?
Check out: Introduction to the Proboard & Propeller Cookbook 1.4
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card connected? - PropDOS
Glad you found the solution to your problem, snot and all - lol
Beau Schwabe
IC Layout Engineer
I think that Image Attachment· say it all
By the way I like the photo that you have here My son also like this photo as well
And your not the only one that has done dumb thinking or just plan stupid thing
before
rjo_,
You are not even close... I have snot coming out of my nose because I laugh so hard every time I think about just how stupid I can be[noparse]:)[/noparse]
I like this but I NEVER heard it that way before
·When I read this I had to laugh
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 8/8/2008 1:15:05 PM GMT
