ESAB Robot memory tape drive retrofit — Parallax Forums
Brian_BBrian_B Posts: 844
edited 2008-08-02 21:44 in Propeller 1
Hi,
·Here is a photo of my newest toy·,A ESAB welding robot and I·just received it today. I powered it up and everything seems to be working except the tape drive is all jamed up. It needs the tape drive remember programs after you teach it. I've included a pinout of the tape drive I/O's ,would it be possible to use a propeller to save and read to a SD card and comunicate the info to the controller?
Thanks'
· Brian
  • RaymanRayman Posts: 16,221
    edited 2008-08-01 01:50
    I have robot envy!· I bet you could do it, but you'd need to figure out the protocol...· If you don't have it, that would probably be the hard part...
  • Brian_BBrian_B Posts: 844
    edited 2008-08-01 03:49
    Hi,
    ·I have a whole book on just the tape drive , is any of this useful ?
    Thanks'
    ·Brian
    582 x 800 - 169K
    582 x 800 - 238K
    582 x 800 - 230K
    edited 2008-08-01 12:34
    At first glance, that does look like the info you need. Looks doable to me. Good Luck!
  • PhilldapillPhilldapill Posts: 1,283
    edited 2008-08-02 07:11
    Brian,
    Just curious - how much was that? I'm gonna have to get me one of those... [noparse]:)[/noparse]
    Philldapill,
    $1500 and I thought it was a steal even if it didn't work. Everything seems to work on it except the tape drive . You put into teach mode ,move it around and it remebers the exact moves you make with it !
    Brian
