5 Mhz crystal in the UK
Why is it so hard to buy a 5 MHz crystal here in the UK?
RS don't have a single 5MHz crystal as far as I can see.
Farnell can supply one in the large HC49U case style but you have to order from the US for the small HC49US case style.·The £15.95 handling charge makes a £0.20 crystal quite pricey!
I also wanted a small SMT variant to go with a LQFN PCB design but I can't find these either.
Anyone help?
Anyone help?
You won't find a small SMT 5 MHz crystal anywhere. I've looked, and they just don't exist. Apparently, the resonant element at that low a frequency has to have a certain minimum size. (I'm sure size is one reason Parallax uses a 10 MHz crystal, instead, on their Spin Stamp.)
One thing you might consider is a cylindrical can-style crystal. They're a bit fragile but keep a low profile when bent over horizontally. Some come in a bent-lead SMT configuration that may prove adequate if you also solder the can to the board.
'Still some PropSTICK Kit bare PCBs left!
Maplin P/no RR79L
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Farnell also do the 'large' case version. I would like the lower profile HC49US as comes on the parallax protoboard
@Phil
Yes, I understood this when I looked at the size of another SMD crystal.·Probably why·some companies produce a SMT variant which is just the HC49US version with the pins bent·thru 90 degrees(plus an insulator)
Didn't try Rapid must admit - I don't buy a lot from them as finding anything in their online catalogue is a real pain. Their webste is unavaialble at the moment but I'll try later
Rapid Electronics used to do 5Mhz in HC49/U. There web site down for maintenance so unable to confirm this
http://www.actcrystals.com/
Leon
