5 Mhz crystal in the UK — Parallax Forums
Paul MPaul M Posts: 95
edited 2008-07-31 18:57 in Propeller 1
Why is it so hard to buy a 5 MHz crystal here in the UK?
RS don't have a single 5MHz crystal as far as I can see.
Farnell can supply one in the large HC49U case style but you have to order from the US for the small HC49US case style.·The £15.95 handling charge makes a £0.20 crystal quite pricey!
I also wanted a small SMT variant to go with a LQFN PCB design but I can't find these either.
Anyone help?
    edited 2008-07-30 16:18
    Paul,
    You won't find a small SMT 5 MHz crystal anywhere. I've looked, and they just don't exist. Apparently, the resonant element at that low a frequency has to have a certain minimum size. (I'm sure size is one reason Parallax uses a 10 MHz crystal, instead, on their Spin Stamp.)
    One thing you might consider is a cylindrical can-style crystal. They're a bit fragile but keep a low profile when bent over horizontally. Some come in a bent-lead SMT configuration that may prove adequate if you also solder the can to the board.
    'Still some PropSTICK Kit bare PCBs left!
  • cheapskatecheapskate Posts: 6
    edited 2008-07-30 16:27
    Maplin have stock in HC-49/U can.
    Maplin P/no RR79L
  • LeonLeon Posts: 7,620
    edited 2008-07-30 16:39
    I bought some from Rapid Electronics: Order code 90-0460
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
  • Paul MPaul M Posts: 95
    @cheapskate
    Farnell also do the 'large' case version. I would like the lower profile HC49US as comes on the parallax protoboard
    @Phil
    Yes, I understood this when I looked at the size of another SMD crystal.·Probably why·some companies produce a SMT variant which is just the HC49US version with the pins bent·thru 90 degrees(plus an insulator)
    edited 2008-07-30 16:42
    Leon
    Didn't try Rapid must admit - I don't buy a lot from them as finding anything in their online catalogue is a real pain. Their webste is unavaialble at the moment but I'll try later
    edited 2008-07-30 16:46
    Why use a 5Mhz crystal, unless you have a reason for this exact frequency. According to page 180 of the propeller manual, _clkmode allows most crystals between 4mhz & 80Mhz to be used and within limits a PLL multiplier. (thats if I understand this correctly!! ).
    Rapid Electronics used to do 5Mhz in HC49/U. There web site down for maintenance so unable to confirm this
    edited 2008-07-30 16:50
    ACT makes the ones that Rapid sells. They make a couple of small surface-mount ones:
    http://www.actcrystals.com/
    Leon
    edited 2008-07-30 16:51
    The datasheet indicates that a crystal between 4 and 8MHz can be used if the PLL is to be used. You can use other crystal frequencies (in fundamental mode ... not in overtone mode) if you are not using the PLL. Obviously, people (including Parallax) are using crystals outside that range (like 10MHz), but that's outside specifications for the full temperature and supply voltage range.
  • hinvhinv Posts: 1,272
    edited 2008-07-31 18:30
    The Prop Dongle uses a 5MHz surface mount crystal.
    hinv said...
    Yes, but it's an HC49/US, not a compact SMD device. In fact, this particular package actually takes up more board space than the equivalent thru-hole part, due to the pads extending beyond the can perimeter.
