Propeller Fire Alarm
Here is a Prop based fire alarm.· It works as a module.· Each alarm module talks to the next one in the system by serial comm.· If one if DOA, the prop behind it will go into an error state.· If one module goes off, each one in the "network" will go off.· Im still working on a good metal case but it is fully operational.
I'd certainly keep a couple of 'off-the-shelf' detectors hanging on the walls just in case!
<FONT>Steve
What's the best thing to do in a lightning storm? "take a one iron out the bag and hold it straight up above your head, even God cant hit a one iron!"
Lee Travino after the second time being hit by lightning!
Congratulations! on completing your project. You do really nice work.
Aka: CosmicBob
How do you detect a fire? Any other features you plan to add?
Timothy D. Swieter, E.I.
www.brilldea.com·- Prop Blade, LED Painter, RGB LEDs, uOLED-IOC, eProto fo SunSPOT, BitScope
www.sxmicro.com - a blog·exploring the SX micro
www.tdswieter.com
Thanks. I etch the board with a homemade etchant tank with hcl and hydrogen peroxide. To lay out the traces I use the press-n-peel paper. Right now its only a fire/tornado alarm. I hope to add some detection to it in the future. The only change will be one module will talk to a pc. when an alarm is set off, the pc will know what alarm was pulled, also the pc will be the only device to activate the tornado alarm.
I like the circuit board too. I have never tried to etch a board myself. Looks great.
What is the surface on the component side of the board? - I haven't seen anything like that before.
Where did you get the blank board?
Whit+
Post Edited (Whit) : 7/29/2008 1:11:03 PM GMT
http://www.allelectronics.com/make-a-store/item/PCB-612/6-X-12-X-0.062-SINGLE-SIDE-PC-BOARD/-/1.html
If your interested, I can give you a step by step on how I make my boards. Its really easy to get good results. and not really that much of an investment(materials, equipment, and time).
