Propeller Fire Alarm — Parallax Forums
Computer Geek 101Computer Geek 101 Posts: 179
edited 2008-07-31 19:03 in Robotics
Here is a Prop based fire alarm.· It works as a module.· Each alarm module talks to the next one in the system by serial comm.· If one if DOA, the prop behind it will go into an error state.· If one module goes off, each one in the "network" will go off.· Im still working on a good metal case but it is fully operational.
1077 x 687 - 177K
939 x 612 - 163K
948 x 860 - 210K
  • steve_bsteve_b Posts: 1,563
    edited 2008-07-23 23:38
    Looks interesting! Many neat things to customize this to!
    I'd certainly keep a couple of 'off-the-shelf' detectors hanging on the walls just in case!
    <FONT>Steve
    What's the best thing to do in a lightning storm? "take a one iron out the bag and hold it straight up above your head, even God cant hit a one iron!"
    Lee Travino after the second time being hit by lightning!
  • Computer Geek 101Computer Geek 101 Posts: 179
    edited 2008-07-25 11:49
    here is the completed case.
    940 x 663 - 186K
    edited 2008-07-28 07:14
    @Computer Geek 101
    Congratulations! on completing your project. You do really nice work.
    Aka: CosmicBob
    edited 2008-07-28 13:22
    thanks. It took the better part of 5 hoours to get the case done. Now I only need to build 6 more!
    edited 2008-07-29 04:01
    That is a nice looking project. I like your circuit board layout too, did you etch that yourself?
    How do you detect a fire? Any other features you plan to add?
    Timothy D. Swieter, E.I.
    www.brilldea.com·- Prop Blade, LED Painter, RGB LEDs, uOLED-IOC, eProto fo SunSPOT, BitScope
    www.sxmicro.com - a blog·exploring the SX micro
    www.tdswieter.com
    edited 2008-07-29 11:30
    @Timothy:
    Thanks. I etch the board with a homemade etchant tank with hcl and hydrogen peroxide. To lay out the traces I use the press-n-peel paper. Right now its only a fire/tornado alarm. I hope to add some detection to it in the future. The only change will be one module will talk to a pc. when an alarm is set off, the pc will know what alarm was pulled, also the pc will be the only device to activate the tornado alarm.
  • WhitWhit Posts: 4,194
    edited 2008-07-29 13:05
    Computer Geek,
    I like the circuit board too. I have never tried to etch a board myself. Looks great.
    What is the surface on the component side of the board? - I haven't seen anything like that before.
    Where did you get the blank board?
    Whit+
    Post Edited (Whit) : 7/29/2008 1:11:03 PM GMT
    edited 2008-07-29 13:14
    here is the pcb. I love this stuff way better than the epoxy. Ist more like a fiber/plastic.
    http://www.allelectronics.com/make-a-store/item/PCB-612/6-X-12-X-0.062-SINGLE-SIDE-PC-BOARD/-/1.html
    If your interested, I can give you a step by step on how I make my boards. Its really easy to get good results. and not really that much of an investment(materials, equipment, and time).
    edited 2008-07-29 19:17
    well....it looks like I'm going to be making a smoke dector. we had a titanium fire. I hope to have the smoke detection done before thursday.
    Here is the smoke detector module.· I hope to have it integrated by Monday.
    628 x 444 - 86K
    390 x 387 - 39K
