New uOLED-96-PROP with 10MHz crystal
Duffer was kind enough to send me one of 4D's new uOLED-96-PROPs with the 10 MHz crystal.
Now, the·onboard Prop·can run at 80 MHz with all the cogs!
Just had to change one line of the code to put in the new crystal value and my driver works just as it should.
Slideshow animation now up to 20 fps.· So, I'd expect some tinkering could get it up to film or possible video refresh rates for uSD card content...
But, the flying dove animation looks very smooth now.
You can see the 10 MHz crystal (the white thing labelled FOX 10.000) in this picture:
hence running at 80mhz?
OBC
New to the Propeller?
Getting started with the Protoboard? - Propeller Cookbook 1.4
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card? - PropDOS
Need a part? Got spare electronics? - The Electronics Exchange
Jim
With 5MHz plus PLL16x or 10MHz plus PLL8x that's a system speed of 80MHz.
I guess the 10MHz was chosen for size. The SpinStamp and Hydra also use 10MHz crystals.
propeller.wikispaces.com/Oscillator
The 8 bit ASM driver I wrote should give killer speed at 80MHz, because it was already super fast at 64MHz.
Timothy D. Swieter, E.I.
www.brilldea.com·- Prop Blade, LED Painter, RGB LEDs, uOLED-IOC, eProto fo SunSPOT, BitScope
www.sxmicro.com - a blog·exploring the SX micro
www.tdswieter.com
