New uOLED-96-PROP with 10MHz crystal — Parallax Forums
RaymanRayman Posts: 16,220
edited 2008-07-29 03:49 in Propeller 1
Duffer was kind enough to send me one of 4D's new uOLED-96-PROPs with the 10 MHz crystal.
Now, the·onboard Prop·can run at 80 MHz with all the cogs!
Just had to change one line of the code to put in the new crystal value and my driver works just as it should.
Slideshow animation now up to 20 fps.· So, I'd expect some tinkering could get it up to film or possible video refresh rates for uSD card content...
But, the flying dove animation looks very smooth now.
You can see the 10 MHz crystal (the white thing labelled FOX 10.000) in this picture:
    edited 2008-07-28 16:34
    Pardon my ignorance, but I thought the original design would have called for a 5mhz,
    hence running at 80mhz?
    OBC
    New to the Propeller?
    Getting started with the Protoboard? - Propeller Cookbook 1.4
    Got an SD card? - PropDOS
    Need a part? Got spare electronics? - The Electronics Exchange
  • JamesxJamesx Posts: 132
    edited 2008-07-28 16:43
    I have received several and all of them so far have had 8 MHz crystals.
    Jim
  • hippyhippy Posts: 1,981
    edited 2008-07-28 18:18
    Without re-running the full debate; the 8MHz crystals can have problems with PLL16x and at PLL8x that limits maximum system speed to 64MHz.
    With 5MHz plus PLL16x or 10MHz plus PLL8x that's a system speed of 80MHz.
    I guess the 10MHz was chosen for size. The SpinStamp and Hydra also use 10MHz crystals.
    propeller.wikispaces.com/Oscillator
    Nice! They are not going to offer this with a 10MHz. crystal? Anything else about the design change or only the one component?
    The 8 bit ASM driver I wrote should give killer speed at 80MHz, because it was already super fast at 64MHz.
    Timothy D. Swieter, E.I.
    www.brilldea.com·- Prop Blade, LED Painter, RGB LEDs, uOLED-IOC, eProto fo SunSPOT, BitScope
    www.sxmicro.com - a blog·exploring the SX micro
    www.tdswieter.com
