Propeller Starter Kit contents — Parallax Forums
SeairthSeairth Posts: 2,474
edited 2008-07-30 22:07 in Propeller 1
I recently got a Propeller Starter Kit.· It also came with an assortment of resistors, capacitors, and switches.· I can figure out the specs of most of the bits, but there are a few that I don't know.· Particularly, there·are two photoresistors.· Does anyone know the specs (or mfr and part number) for them?· In fact, if there is an available inventory, that would be nice to get too.
  • SeariderSearider Posts: 290
    edited 2008-07-27 03:33
    If you go to the component section of the Parallax store you should be able to find each of the items in the grab-bag along with the data sheets.
    Searider
    edited 2008-07-27 04:02
    Actually, this isn't an unreasonable request..
    The PEkit has inventory lists, but I couldn't find one for this when I went looking..
    Parallax Sales?
    OBC
    New to the Propeller?
    Getting started with the Protoboard? - Propeller Cookbook 1.4
    Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
    Got an SD card? - PropDOS
    Need a part? Got spare electronics? - The Electronics Exchange
  • parts-man73parts-man73 Posts: 830
    edited 2008-07-27 05:47
    http://forums.parallax.com/showthread.php?p=639062
    this thread has a list of the Propeller education kit and a breakdown of just the "DIP plus" kit
    Brian
    uController.com - home of SpinStudio - the modular Development system for the Propeller
    PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
    SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
  • SeairthSeairth Posts: 2,474
    edited 2008-07-30 00:38
    Searider said...
    I see that. However, the product description for the photoresistor was not specific enough. The PDF lists 8 different parts, each with different specs. Hooking the one I have up to an meter, I think the one that was included in the kit was the VT90N1. But even those numbers don't match up to what I was seeing on the meter. I would prefer to know exactly what I have instead of having to infer it through means like this.
    edited 2008-07-30 21:27
    Seairth,
    It should be this Perkin Elmer part:
    http://www.alliedelec.com/Search/ProductDetail.aspx?SKU=980-0105
    Thanks for getting back to me. The one I got looks and acts (according to the spec sheet) much more like this part:
    http://www.alliedelec.com/Search/ProductDetail.aspx?SKU=980-0010
