Parallax wheel/motor Object
Hi,
·Has anyone written a object for the new Parallax wheel/motor combo's ? If not i'll start on one.
Thank's Brian
·"Imagination is more important than knowledge..." ·· Albert Einstein
www.PropelX.com
www.NorthStarMachining.com
Thank's Brian
www.PropelX.com
"A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
DGSwaner
You can certainly expand upon it if you wish. Hope this helps.
Steve Norris
www.norrislabs.com
These Motors are beautiful, I have to find a reason to justify buying them...
the controller/encoder allows you to set max speed, ramp rate, go a certain number of "ticks" stay at a position, and probably more I'm not remembering. you could use Norris's code and not HB25's but, with them it's a really good setup.
I tried to not use the HB25's at first thinking I could find a cheaper or better solution. I finally realized that they are well worth the money, and I could find no equal for the price.
DGSwaner
Thanks for the info.
It will work just fine .
Thank's Brian
www.PropelX.com
