High-Voltage Sensor
I need to build a sensor that goes high when a spark on a lawn mower engine fires. This will be interfaced with a BASIC Stamp from the kit Radio Shack sells.
Only the timing is important, I don't need to measure the actual voltage.
However, the voltage is somewhere between 10,000 and 20,000 volts.
I believe an inductance coil wrapped around the spark plug wire and an opto-isolator to do the interface.
Does anyone know how many turns of wire needs to be around the spark plug wire. How to prototype and test?
Is there a better way?
Thanks!
- Bill
Thanks!
- Bill
Post Edit -- The sparking will result impulse noise (static) which the radio will give evidence of, and it won't require any interface to high-voltages, coil winding, etc.
Post Edited (PJ Allen) : 7/21/2008 2:45:56 AM GMT
Post Edit -- The interface would basically·be a patch cord from the radio's earphone jack to the Stamp.
Post Edited (PJ Allen) : 7/21/2008 2:52:09 AM GMT
The other thing, is that there are premade current transformers you could just purchase.
