High-Voltage Sensor — Parallax Forums
High-Voltage Sensor
CharosCharos Posts: 7
edited 2008-07-24 00:56 in General Discussion
I need to build a sensor that goes high when a spark on a lawn mower engine fires. This will be interfaced with a BASIC Stamp from the kit Radio Shack sells.
Only the timing is important, I don't need to measure the actual voltage.
However, the voltage is somewhere between 10,000 and 20,000 volts.
I believe an inductance coil wrapped around the spark plug wire and an opto-isolator to do the interface.
Does anyone know how many turns of wire needs to be around the spark plug wire. How to prototype and test?
Is there a better way?
Thanks!
- Bill
    edited 2008-07-21 02:27
    I think any AM radio, especially if tuned to a spot where there is no station broadcasting,·would give an excellent result.
    Post Edit -- The sparking will result impulse noise (static) which the radio will give evidence of, and it won't require any interface to high-voltages, coil winding, etc.
    Post Edited (PJ Allen) : 7/21/2008 2:45:56 AM GMT
  • CharosCharos Posts: 7
    edited 2008-07-21 02:41
    You might notice the goal is to interface the signal with the BASIC Spark CPU.
    edited 2008-07-21 02:44
    So what's your point?
    Post Edit -- The interface would basically·be a patch cord from the radio's earphone jack to the Stamp.
    Post Edited (PJ Allen) : 7/21/2008 2:52:09 AM GMT
    edited 2008-07-23 01:44
    Is there a circuit that would not require an AM radio? I use mine to listen to music made by my TRS-80....
  • whickerwhicker Posts: 749
    couldn't you just paint a mark on the flywheel, or shaft, and use an optical sensor to see it?
    The other thing, is that there are premade current transformers you could just purchase.
