Oh no...
CannibalRobotics
I'm only getting about 2 volts out of P4 - P7 even when they are not connected to anything. I've tried pull up resistors but no help. All of the others seem to be working fine.
Do I need to dig another propellor grave?
Jim-
Jim-
If so, you should definitely get voltages more like 3V - 3.3V unless they're connected to a significant load. 2V sounds just
wrong. Are you measuring it correctly? Is there a short on your board on pins P4-P7? Did they used to work?
