Seetron Serial LCD troubles...
Hi all,
Okay, I'm finally back to this serial lcd hookup project...
I've got a Seetron bpp-420vy serial LCD 4x20
+5, -, and serial (rs232 or inverted TTL)
I have the serial connected to P5 and am using "simple serial"
I just get garbage on the screen...
Hee is the code
Any thoughts why I'm getting garbage? I tried this on 2 different, but same, LCD's and they both do the same thing (garbage)
~Kam (^8*
Hee is the code
CON
_clkmode = xtal1 + pll16x ' use crystal x 16
_xinfreq = 5_000_000 ' 5 MHz cyrstal (sys clock = 80 MHz)
' setup serial pins
outputPin = 5
inputPin = -1
baud = 9600
' debug pins
LEDPinGood = 16
LEDPinBad = 23
OBJ
serial : "simple_serial" ' bit-bang serial driver
PUB main
' turn off LED's
dira[noparse][[/noparse]LEDPinGood]~~
dira[noparse][[/noparse]LEDPinBad]~~
if serial.init(inputPin, outputPin, baud)
!outa[noparse][[/noparse]LEDPinGood] ' turn on good led
serial.tx(12) ' clear screen
serial.tx(6) ' blinking cursor
serial.tx("K")
serial.tx("a")
serial.tx("m")
else
!outa[noparse][[/noparse]LEDPinBad] ' turn on bad led
repeat
~Kam (^8*
'' To specify inverted baud (start bit = 1), use a negative baud value:
'' serial.start(0, 1, -9600)
Ooops, sorry, I forgot to mention I did try the negative baud also...it's just not writing "kam" on the screen...I get garbage, or "ka" etc...maybe a timing thing or something...I'll have to put my analizer on it...
But, the code it sound and hook up, ya?
I continue....
~Kam (^8*
Hope that helps
Shawn Lowe
When all else fails.....procrastinate!
How did you adjust the timing? I did notice that if I put "stalls", I can get my name to appear at times...I've used these displays without any issues before on a pic...
Stupid Prop chip...working to fast...
~Kam (^8*
also a good reference http://www.seetron.com/ser_an1.htm
Are the LCD and Properller circuit grounds common..Just a thought..
John
'Necessity is the mother of invention'
Post Edited (QuattroRS4) : 7/15/2008 6:51:31 PM GMT
Shawn Lowe
