Seetron Serial LCD troubles... — Parallax Forums
KamPuttyKamPutty Posts: 48
edited 2008-07-15 18:46 in Propeller 1
Hi all,
Okay, I'm finally back to this serial lcd hookup project...
I've got a Seetron bpp-420vy serial LCD 4x20
+5, -, and serial (rs232 or inverted TTL)
I have the serial connected to P5 and am using "simple serial"
I just get garbage on the screen...
Hee is the code
CON
  _clkmode = xtal1 + pll16x                             ' use crystal x 16
  _xinfreq = 5_000_000                                  ' 5 MHz cyrstal (sys clock = 80 MHz)
  ' setup serial pins
  outputPin = 5
  inputPin  = -1
  baud      = 9600
  ' debug pins
  LEDPinGood = 16
  LEDPinBad  = 23
OBJ
  serial : "simple_serial"                              ' bit-bang serial driver
PUB main
  ' turn off LED's
  dira[noparse][[/noparse]LEDPinGood]~~
  dira[noparse][[/noparse]LEDPinBad]~~
  if serial.init(inputPin, outputPin, baud)
    !outa[noparse][[/noparse]LEDPinGood]                                   ' turn on good led
    serial.tx(12)                                       ' clear screen
    serial.tx(6)                                        ' blinking cursor
    serial.tx("K")
    serial.tx("a")
    serial.tx("m")
  else
    !outa[noparse][[/noparse]LEDPinBad]                                    ' turn on bad led
  repeat
Any thoughts why I'm getting garbage? I tried this on 2 different, but same, LCD's and they both do the same thing (garbage)
~Kam (^8*
    edited 2008-07-14 20:13
    From the Simple_Serial comments:
    '' To specify inverted baud (start bit = 1), use a negative baud value:
    '' serial.start(0, 1, -9600)
  • KamPuttyKamPutty Posts: 48
    edited 2008-07-14 23:05
    Mike, et. al.,
    Ooops, sorry, I forgot to mention I did try the negative baud also...it's just not writing "kam" on the screen...I get garbage, or "ka" etc...maybe a timing thing or something...I'll have to put my analizer on it...
    But, the code it sound and hook up, ya?
    I continue....
    ~Kam (^8*
  • Matthew HayMatthew Hay Posts: 63
    edited 2008-07-15 01:41
    Well the first thing that I notice is that you don't have any delay before trying to use the LCD. The examples on seetron's site show a 1 Sec delay to allow the LCD to stabilize. I also noticed that the lcd has a couple of switches for settings on the back, one being for baud rate 2400/9600 and the other being for mode selection normal/old, you might want to verify those match up appropriately too.
  • Shawn LoweShawn Lowe Posts: 635
    edited 2008-07-15 03:23
    Any problems Ive had with my seetron (2X16 and not using a propeller) had to due with timing problems (resonator with an SX)
    Hope that helps
    Shawn Lowe
    When all else fails.....procrastinate!
    edited 2008-07-15 14:51
    Hi shawn,
    How did you adjust the timing? I did notice that if I put "stalls", I can get my name to appear at times...I've used these displays without any issues before on a pic...
    ~Kam (^8*
  • QuattroRS4QuattroRS4 Posts: 916
    edited 2008-07-15 18:34
    Is this an old or new version .. Apparently there has to be a 1mS delay after clearing the screen in the older versions .. see attached jpg .. I have also attached the user pdf in case you didn't have it ..
    also a good reference http://www.seetron.com/ser_an1.htm
    Are the LCD and Properller circuit grounds common..Just a thought..
    John
    'Necessity is the mother of invention'
    Post Edited (QuattroRS4) : 7/15/2008 6:51:31 PM GMT
    717 x 279 - 54K
    pdf
    143K
    bpp.JPG 53.9K
    bpp.pdf 143.3K
    I had to use a resonator, which is precise enough for communications with the LCD. Are you sure you have the right baud setting?
    Shawn Lowe
