Propcorder - a general purpose Propeller powered LCD/button interface idea — Parallax Forums
Timothy D. SwieterTimothy D. Swieter Posts: 1,613
edited 2008-07-29 03:57 in General Discussion
In another thread I started talking about a general purpose LCD/button user interface product idea for Brilldea.· I have pieced together more thoughts about this product and I wanted to seek advice from those visiting the Sandbox.
The intent of the product is to provide a platform upon which other applications can be built.· The platform at a minimum would include an LCD, a configurable button arrangement, voltage regulation and expansion headers.· I attached a picture of a "prototype"·sketch of the device with some of the potential components overlaid on the sketch.·
Possible uses for this device include:
  • thermostat (another thread on thermostats·inspired me to finally get off the fence with this idea)
  • home automation interface
  • handheld test equipment
  • industrial system interface
  • Lighting system controller
  • remote sensor display and data logging
  • handheld propeller video games
  • robotics
  • Tricorder unit!
A working name for the product is Propcorder based on the idea of the Tricorder from StarTrek.
A little more detail.· This is all preliminary and your feedback is welcomed to improve this spec.· Remember this product is trying to be a platform for add-on boards and not a kitchen sink to have all possible interfaces because those can be added with the add-on boards.
  • A two layer PCB approximately 4.0" x 2.25".· The PCB would have small mounting holes in the four corners.
  • Power comes in at the bottom of the PCB.· I have not decided on the footprint for this part yet.· Maybe there would be multiple footprints like one for a DC barrel jack, one for a blue terminal block (like in the picture) and one for two wires.
  • On-board voltage regulation for 5V and 3.3V.· I want to investigate regulators to use.· On a previous product, the Prop Blade, I used the LM1086 which is what the Propeller Protoboard uses.· I would like to consider different regulators so that the incoming voltage can be 12V DC or maybe even 24V DC.· Any suggestions on·specific regulator products to look at?·
  • An on/off switch at the top of the PCB.· This switch could be populated or it could be left off and a jumper installed for always on applications.· An LED near the power switch would indicate power is on.·
  • A 128 x 96 monochrome LCD with four grey scale levels.· The LCD would have·a white·backlight.· Here is a video on YouTube of the LCD on a test bench.· Watch the video in high resolution, it is a much better representation.
  • A button array that can handle up to 12 tactile buttons.· The PCB could be populated with only the buttons needed.· If your application only uses two buttons, then only populate two buttons.· If your applications wants one button on the left and three on the right, then populate that way as well.
  • An led at the top of the PCB (near the on/off switch) that is a general purpose LED.
  • QFP Propeller with a 5 MHz. crystal.· Two eeproms, or at least a spot for up to two eeproms with at least one populated for the boot eeprom.·
  • Programmed via the Prop Plug.
  • MicroSD slot - maybe.· This would be a nice addition, but I am not sold on the idea yet.
  • Two groups of 0.1" spaced headers.· Maybe 10 pins each or 12 pins each side.· These are the expansion·headers for attaching protoboard or perf board or custom PCBs.· The expansion headers could have one large PCB installed on it or two smaller PCBs.· The headers are shown in the photo, but it is not crystal clear how to use them since I didn't draw add-on cards.· Each header group would have the unused I/O as well as the other I/O such as the I2C bus.· Also, the 3.3V, 5V and Incoming power to the PCB could be made available on the expansion headers.·
I really like the expansion header idea and I need to draw a couple more layout to get the layout right.· Brilldea would offer proto boards or maybe specific cards for different applications.· Again, the add-on cards could span one group of expansion headers or both groups.· Maybe I will have a means to have a larger PCB that is the same size as the Propcorder.· I need to be careful of component heights for the components chosen.
For a little while I thought about using a capacitive touch button arrangement on the Propcorder (like your iPOD).· I am shying away from it now though because the IC would complicate the design slightly and may also complicate the software.· Also, in the future maybe Brilldea can offer a case for this design.· If I did that, the cap sense buttons would have some constraints to what materials the case can be made out of and dimensions around and near the buttons.
I need to do more design and research before pricing can be considered.· I also need to review if full or partial assemblies would be sold or if it would be a kit·with "some assembly required".
What are your thoughts?· What should be added or taken away?· Is the Propcorder a good name?· What applications would you use the device in?
Timothy D. Swieter, E.I.
www.brilldea.com·- Prop Blade, LED Painter, RGB LEDs, uOLED-IOC
www.sxmicro.com - a blog·exploring the SX micro
www.tdswieter.com
    edited 2008-07-12 11:03
    I should add, with the feature list as it stand the I/O used is 21 (out of 32). Some of those I/Os though are the I2C bus and the Rx/Tx pins. That means there would be 11 totally free I/Os and a few multipurpose I/Os available on the expansion header.
    www.tdswieter.com
  • John AbshierJohn Abshier Posts: 1,116
    edited 2008-07-12 13:53
    I would make the IO heads 3 row--power, signal and ground. Divide the input headers into 2 groups. Each group is jumper selectable for 3.3 or 5 volts.
    John Abshier
  • jeffjohnvoljeffjohnvol Posts: 197
    edited 2008-07-12 14:51
    Timothy, sounds like a nice feature set.· My thoughts (no offense if ideas not used):
    • Micro SD slot, Yes, I really like that.· Makes logging and transporting updates/config easier.
    • Maybe a shift register for outputs to gain back what may be lost on your board perhaps?
    • Shift register to allow more inputs too?
    • Optoisolation?· Of course this may be getting into the realm of PLC and ot be what you are looking for, but if it only adds a dollar to the board... (guessing)
    • 1 wire interface that would allow your board to receive or transmit any information to another board, or PC perhaps.
    • Maybe screw in terminal blocks under the case to make field wiring easier?· Many tstats have a mount plate with the terminal blocks, and you snap the thermostat on and there is a header that plugs into the mounting plate.
    • Common sensor inputs built in?· Such as temp/RH sensors with a library to get the data.
    • A/D inputs?· You don't have to include the A/D chip, just give the capability to plug one in and have 4 A/D's
    It may also be worth considering having different types button layouts, which I know wouldn't be economical selling this as a hobbiest board, but unless I'm wrong, I can see some people using your platform to make a product and then ask for 100 of them at a pop.· If you had different button platforms that people could purchase and snap in (maybe a numeric pad, or some scroll bars, or 4 push buttons) and you could produce them inexpensively where you are, it could give you more selling options in terms of accessorizing.
    I was looking at that infinity thermostat I have to see what I liked about its UI.· One nice thing about it is that it has 4 side buttons on it that are at each corner of the lcd.· This is very nice, becasue sometimes the system will ask for a specific input, and have the options displayed on the lcd next to the appropriate buttons.· I think this would be nice for any application, not just a t-stat.· I also noticed that my tstat LCD is black/white like yours and has shades of grey which they use nicely.· I think your LCD will do well.· The link below doesn't show the bottom panel that is opened up, there is more config buttons there.
    http://www.residential.carrier.com/products/controls/infinity.shtml
    Note, I'm referencing a tstat because its the only wall mounted device I know of, other than my alarm panel, and its UI isn't that nice.
  • BeanBean Posts: 8,129
    edited 2008-07-12 15:40
    Timothy,
    · Maybe bluetooth as an option ?
    · Then you could have the tstats talk to each other, and to the furnace wirelessly.
    · Just an idea...
    Bean.
    "A government big enough to give you everything you want, is big enough to take away everything you·have."·· Thomas Jefferson
    "It is our choices, Harry, that show what we truly are, far more than our abilities."·Dumbledore from Harry Potter
    www.iElectronicDesigns.com
    edited 2008-07-12 16:57
    Bluetooth might be overkill, zigbee seems well suited to low speed data transfer at really low power.
    - Stephen
  • Desy2820Desy2820 Posts: 138
    edited 2008-07-12 18:02
    Couple of inputs...
    As you stated in another thread, the ability to flip the display between portrait and landscape.· Maybe by using different display pin headers and reading a jumper?
    A group of pads for off-board keypads, especially for interfacing a telephone type keypad.· I would also like at to be able to add at least sixteen buttons, in a 4x4 electrical matrix.· Maybe consider 20 buttons max? (4x5 array?)
    On-board multi-channel ADC chip, suggest at least four input channels.
    User-populated area for MAX232 type chip?· Would allow for RS-232 or RS-485 communications.
  • ForrestForrest Posts: 1,341
    edited 2008-07-12 20:32
    If you really want to go after the video game market or the Tricorder, you should a color LCD.
    Also, base the size of the display and the button layout on an off-the-shelf enclosure.
    A good looking enclosure is what separates a one-off prototype and a successful kit IMHO.
    edited 2008-07-13 07:18
    Thank you for the feedback so far.· This is thought provoking.
    Power and Expansion headers.
    • I want to sketch out a couple ideas for power and layout.· I was thinking that all power busses would be on the expansion header (input power, 5V, 3.3V), not just jumper selectable power.· Maybe I am misunderstanding what you are suggesting.
    On-board radio.
    • I briefly thought of the idea of an on-board radio or at least a spot to populate one.· I was thinking more of zigbee than bluetooth.· I will have to do some research and reading and consider this further.· Several of the potential applications for Propcorder would benefit from a radio on-board.· I am in favor of the idea if I can find a reliable source of radio assemblies that are low cost and easily soldered into the system.
    User Interface.
    • I will keep exploring a way to have the device used in portrait or landscape mode.· With the current design, you could turn the whole device side ways and then the buttons are on the left or the right.· If only the screen is turned side ways the buttons would be on the bottom and the device would be more t-shaped.· Which do you prefer, t-shape or just turn the device side ways?· Heck, put an accelerometer on an expansion board and write a little code and the display can react appropriately like the iPHONE.
    • For the current button configuration, maybe I can leave areas to be populated so that add-on boards for the buttons is possible.· An add-on button/slider/etc type board may sit a little higher than I wuld like, but it would be possible.· A base product could come with the tactile buttons to be populated on the base circuit board or add-on boards for specific arrangement of buttons could also be placed over where the tactile buttons would noramlly go.· If a larger array of buttons was needed, the add-on board could do that through the I/O on an add-on button board.· Make sense?· I am trying to say there would be add-on boards for the back, but also the button area could be an add-on board.
    • I like the idea of buttons at the corners of the screen.· How could I do that here?· Maybe just one tactile buttons in each corner of the LCB?· The device would be wider than 2.25" and a little more I/O would get used.
    Other I/O and part requests.
    • I think MicroSD should be included.
    • I need to think through adding footprints for unpopulated functions like the RS232 or additional I/O through GPIO expansion chips.
    • Many of the ideas for ADC, 1-wire and similar are what I was thinking the add-on boards on the back would do.· Not every application requires these interfaces, so I would like to keep as much general purpose I/O free so that the add-on boards can be application specific for just what the application needs.
    • Enclosure.· It would be nice to make a custom enclosure for this device.· I·know of the resources over here to do that,·they·are reasonably price·but·they still are not cheap.· I can see the benefit of designing this device to fit an off the shelf enclosure.··I will have to research this.· Do you have an enclosure in mind?
    • Color screen.· I don't think this is going to happen.· I am trying to keep the cost low and the programming resources for the graphics portion low as well.· I have access to the mobile phone markets where just about every type of screen can be bought, but those sources are not necesarily reliable, they are inexpensive though.· I also have sources for active matrix·OLEDs, but those are expensive.· The Propeller also has limited memory and having a color screen with 8-bit color at 128x96 takes up a lot of memory.· For now I am not convinced that a color screen should be had on the general purpose device.· There would be a WOW! factor, but the cost could go up too.· This device isn't targeted towards being a propeller handheld video game system, but it is an option for creating games on and experimenting with the idea since is has a screen and buttons and easily fits in your hand.
    Keep the ideas and feedback coming.
    www.tdswieter.com
    edited 2008-07-13 07:20
    Here is a link to the thermostat user guide that Jeff mentioned.· I see better the button arrangement with the picture on page 3.
    Infinity Control user guide.
    www.tdswieter.com
    edited 2008-07-14 00:48
    Timothy
    This thermostat is a very good
    I am a A/C Tech by trade
    A few though that·I would like to have if i where going to built one I will keep watching this post to see what you come up with
    # 1 There need filter reminder when to change it base on hour of running for cooling and heat (If done right would also know how much of the time you unit is running in a month)
    #2 Thermostat Zones names are a good idea· I·wish that there was one on the market for home use this would where you have a Thermostat in every
    room in your house
    #3 Adaptive mode where it Will learn how long it take to cool down you house
    when you need it be cool down when you come from work ( it would nice if you can tweak as well
    #4· Home, Away, Sleep, Weekend, Vacation timers
    #5 Fan speed control this is a nice idea for home A\C unit
    You can get· these units but they are only for 15 sheer and up
    what is need is fan control for unit that are under 15 sheer you could choose
    Cooling one of two speeds·High·or Med speed·base on suction line temp an RH %·level
    Fan speed would Med·or Low if air handler has Three speed fan or not
    Heat one of two speed base on temp on the heat strip
    Heat one of two speed base on suction line temp and room temp
    #6 Have a out side damper option where between Spring and Summer You could have outside air only base on side temp and RH % level
    ··Thanks for any·idea.gif·that you may have and all of your time finding them
    Sam
    Post Edited (sam_sam_sam) : 7/14/2008 1:22:16 AM GMT
    edited 2008-07-14 01:33
    Sam, Timothy's goal here is to create a generic platform to create whatever product you like, so what you define would be done in software on his proposed board.
    edited 2008-07-14 01:43
    Timothy, I don't think any single button layout will please everyone, so what if you had a housed unit that only included the LCD and 4 basic buttons, with one twist. On the bottom and side of the unit, a panel could be removed, and a button panel plugged into the unit such that it looks as though it originally belongs to it. In other words, when the button panel (of whatever sort you make, blends into the unit so the casual observer would think that it was meant to be that way (sorry if this sounds confusing, hard to explain).
    This would do two things. One, it would solve your portrait/landscape issue, and you could have a couple of different layouts (if you want). Or, just have a generic one for now and consider more later. Or... Supply a generic plug in board where people could lay out their own buttons.
    The problem with this solution is that your basic board would have to fit within the footprint of the basic LCD. The positive is that in some cases, someone may prefer the smaller panel where there is just the LCD and 4 control buttons (as in a home control unit of some sort). I could see that, if I had an LCD in each bedroom, I could see where I could accomplish most things, bump up temp, see outside temp etc with just the 4 buttons.
    edited 2008-07-15 09:36
    Jeff -
    I like your idea of plugable button board. I can see that it would lend itself to the users being able to get what they want. On the other hand though it might complicate the design and at a minimum the cost of PCB tooling and designing seperate boards would go up. The idea is good and it would make the tricorder idea more general purpose than it is now.
    Hmmmm....
    Is there a generic enough interface that could be designed that would make it appeal to the masses? I always like the idea of a scroll wheel/jog dial and a couple buttons. I really like the iPOD like interface and I started a UI a while ago on the uOLED-PROP-96 that simulated this but I never finished that software. Something similar could be done on this complete with capacitive sensing scroll wheel or a mechanical one. The capacitive sense has its advantages and disadvantages though.
    The design shown in the picture can't get any taller without exceeding my current license on EAGLE for PCB size. The board could get wider, but then it might feel funny in the hand for those potential hand applications.
    Maybe I am trying to tossout too wide of a net by trying to make the design expandable and appealing to many. The goal of this product design is to provide a platform for a user interface consisting of an LCD and buttons and maybe an LED or two. The platform should lend itself to be as open, expandable and available for whatever the application may be.
    Right now I am going to stay focused on the LCD, button, interaction design issue and see what other ideas I come up with.
    www.tdswieter.com
    edited 2008-07-15 12:32
    Probably the best thing to do is to build something that you think you would like to use. Then, if successful you can play with phase 2 after you see what any shortcomings there may be in the prototype.
    edited 2008-07-15 12:40
    Timothy, if you wanted to allow a wall mount for your propcorder, this is an example of what I was talking about in terms of allowing an easy wall mount.· Notice this can be mounted and wired, then the device would snap in.· It makes hooking up the wires and installing much more professional.
    800 x 533 - 129K
    Thank you for the wisdom Jeff. You are right. Every day when I start designing and dreaming I tell myself that iteration is the best thing for designing. Inevitably I get stuck in an "infinite loop" where I keep trying to tweak and improve and make better something before I design it in detail and make it.
    Iteration is a very, very important part of design - especially when it involves design for others. Tweaking and improving can be done only with feedback from using and trying it out.
    www.tdswieter.com
    edited 2008-07-26 10:19
    OK - this hasn't gone dead yet.· I have been researching a few different ideas for the user interface.· I would like to go with a capacitive touch sensor design and metal dome style buttons.· I attached a picture of one of my latest sketches.· I am still doing hardware research.· Maybe with this design the device could be called an iPROP.
    The idea is still to provide a generic user interface in hardware and software and then add-on boards could be attached to the back of the device.· I am trying to limit the I/O usage on the user interface to allow for the max number of I/O on the expandable headers on back.·
    www.brilldea.com·- Prop Blade, LED Painter, RGB LEDs, uOLED-IOC, eProto fo SunSPOT, BitScope
    www.tdswieter.com
    1024 x 768 - 39K
  • parts-man73parts-man73 Posts: 830
    edited 2008-07-27 15:49
    How about using LED's as buttons?
    Like this example - www.youtube.com/watch?v=7kzIHMpOt20
    That would give it an ultra-cool look and feel. for the jog wheel you have sketched out, you could use leds set in a circle.
    You may need a slave processor so that you aren't using too much of the Propellers resources (both cogs and IO lines) you run the display/input system.
    Brian
    uController.com - home of SpinStudio - the modular Development system for the Propeller
    PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
    SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
  • SeariderSearider Posts: 290
    edited 2008-07-27 19:37
    The LED touch panel would look cool but think of the power needed to light all those LEDs. This would limit the use on battery powered systems.
    Searider
    edited 2008-07-27 22:21
    I considered an LED interface.· A few months ago I experimented with them but the results are finiky.· The system would need to be calibrated for different environments.· It is a good idea though.
    The center scroll wheel is a capacitive sensor.· There is a metal dome button in the center and then three on each side of the scroll wheel.· I am considering have the six outside buttons be backlight metal dome.· Those six metal domes would have a hole punched in the center.· The PCB would also have a hole an a SMT LED would be mounted on the back of the PCB.· Then the button can be light up.· In the drawing actually drew an LED next to the button, but I like the backlight idea better.
    www.tdswieter.com
  • CounterRotatingPropsCounterRotatingProps Posts: 1,132
    edited 2008-07-27 22:34
    Timothy,
    this is a nice idea - go with the Tricoder idea! I mean, look at those wheels under the tricorder's front flap. They are wheels aren't they? Don't know how you'd hook pots up to them... or maybe use an optical encoder. A few less buttons and more wheels. Have several screen resolution options. And I'd have a case, like the tricoders, or some enclosure with only a three or four connectors: USB, XLR (3 or 5 pin), power in, and ???
    thanks for sharing this project.
    - Howard in Florida
    Buzz Whirr Click Repeat
    Thank you for the feedback. I will have to search out more Tricorder pictures, but I am not trying to duplicate it exactly. I am more or less trying to get a generic interface that can do have hardware attached to do everything, like a Tricorder.
    In time I may be able to provide a case or so. Tooling and production in China isn't too bad, but is still an investment that would need to be pay off.
    www.tdswieter.com
