Troubles getting started
I am very new to the propeller and have been working through the PE kit tutorials without a problem, but when I try working on something different like the ping)) sensor, I can never get it to work. I'm not sure if I'm missing something in the programming or if my problem is with the wiring, but I can never get it to work. I put the correct pin number into the code, but is there anything else I should do? I tried both the ping and servo programs and neither will work.
Can you post the code that you have tried so far for the PING))) ?
Beau Schwabe
IC Layout Engineer
It is good to hear you are working through the PE Kit tutorials. Those are the first place to learn about the Propeller. Posting your code, as Beau suggested, would help us help you. You can use the archive features of the Prop Tool to create a zip file. Then post that zip file on the forum. Also, maybe you can post a picture or two of the PING)) connected to your circuit. Then maybe we can help verify the wiring you did.
Timothy D. Swieter, E.I.
www.brilldea.com·- Prop Blade, LED Painter, RGB LEDs, uOLED-IOC
www.sxmicro.com - a blog·exploring the SX micro
www.tdswieter.com
The Pi Guy
