Eagle : How to save a part in a Schematic or Layout as a library part
william chan
Hi,
I have some Schematics and Layout that contains some custom components.
How do I save these custom components in my library so I can edit and use them later in my own boards.
Thanks.
www.fd.com.my
www.mercedes.com.my
Thanks.
www.fd.com.my
www.mercedes.com.my
Paul Baker
The component is not yet in any library, so it can't be found in the part tree.
It only exists in SCH and BRD files.
I want to import it into a library.
www.fd.com.my
www.mercedes.com.my
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Paul Baker
One is the use parts exactly as they exist from the library and add new parts each time you cannot find something. This is the 'correct' way to use it. In order to do so, one has to learn how to create new parts for the library. Something I haven't yet mastered as the parts library is the most tedious part of learning any electronic CAD software. Also, in the beginning it is difficult to be sure that I am not creating duplicates under a different name.
The second way is to cheat a bit.
I just use a part that has similar function and footprint. These I completely re-lable in the schematic and the outcome is I have a board in less time. But I don't think you can simply copy these 'cheats' into the library. I suspect you have to start from scratch with the library part creating software.
PLEASE CONSIDER the following:
Do you want a quickly operational black box solution or the knowledge included therein?······
http://www.youtube.com/watch?v=t8Lbdfwjebk
The YouTube link is very helpful.
I like it, others balked and moved on to other stuff - but it isn't that hard.
