Has anyone programmed the SX48 with the USB sx-key ?
Bean
I'm trying to program an SX48 with the USB version of the SX-Key and it doesn't seem to be working.
If I do DEVICE->READ it says it is an SX18 and the ID is just a mess of characters ???
It programs okay with the Serial SX-Key, and I can program SX28 with the USB version without problems.
Bean.
"A government big enough to give you everything you want, is big enough to take away everything you·have."·· Thomas Jefferson
"It is our choices, Harry, that show what we truly are, far more than our abilities."·Dumbledore from Harry Potter
www.iElectronicDesigns.com
Bean.
I just took my USB SX-Key and programmed an SX-48 proto-board. No problems. I have no resonator on the board, and no external circuitry attached.
Interestingly, I thought that the ID was something that wasn't properly supported in the Beta IDE, but the ID string came up perfectly for me.
PeterM
Bean.
in the meantime, I have programmed about 100 SX48s with the new SX-Key USB and the current IDE Beta version w/o problens. I also did some debugging, and it also worked.
I'm curious to know what went wrong on your side, so please keep us posted.
Greetings from Germany,
G
It programs without any errors, but the SX doesn't run. And when I read back the device, it says it is a SX18 and the ID is just garbage.
I'll try removing the resonator when I get a chance.
Bean.
Man! I can't resist this! ME trying to help YOU! [noparse]:)[/noparse]
I am using one of Robert Doerr's SX48 40 pin modules in a PDB and I program it with an SX-Key (USB). I am very advanced with it, having made an LED blink quite successfully.
I hope this helps.
--Bill
You are what you write.
I don't know what was wrong, but it's working fine now...
Bean.
It was doubtless my help that did it. Feel free to pass it along to others. [noparse]:)[/noparse]
--Bill
