Has anyone programmed the SX48 with the USB sx-key ? — Parallax Forums
BeanBean Posts: 8,129
edited 2008-07-11 21:34 in General Discussion
I'm trying to program an SX48 with the USB version of the SX-Key and it doesn't seem to be working.
If I do DEVICE->READ it says it is an SX18 and the ID is just a mess of characters ???
It programs okay with the Serial SX-Key, and I can program SX28 with the USB version without problems.
Bean.
"A government big enough to give you everything you want, is big enough to take away everything you·have."·· Thomas Jefferson
"It is our choices, Harry, that show what we truly are, far more than our abilities."·Dumbledore from Harry Potter
www.iElectronicDesigns.com
  • PJMontyPJMonty Posts: 983
    edited 2008-07-09 23:35
    Bean,
    I just took my USB SX-Key and programmed an SX-48 proto-board. No problems. I have no resonator on the board, and no external circuitry attached.
    Interestingly, I thought that the ID was something that wasn't properly supported in the Beta IDE, but the ID string came up perfectly for me.
    PeterM
  • BeanBean Posts: 8,129
    edited 2008-07-10 02:12
    Okay I'll investigate some more to see what is going on...
    Bean.
  • Guenther DaubachGuenther Daubach Posts: 1,321
    edited 2008-07-10 08:14
    Bean,
    in the meantime, I have programmed about 100 SX48s with the new SX-Key USB and the current IDE Beta version w/o problens. I also did some debugging, and it also worked.
    I'm curious to know what went wrong on your side, so please keep us posted.
    Greetings from Germany,
    G
  • T&E EngineerT&E Engineer Posts: 1,396
    edited 2008-07-10 11:38
    Yes me too. I just ordered a new USB SX Key (along with a Serial to USB cable for my other Serial SX Key) and it looks like I may have to go to a SX48/52 protoboard.
    edited 2008-07-10 11:46
    The only things out of the ordinary is that I have a 20MHz resonator installed, and I'm using the WATCHDOG.
    It programs without any errors, but the SX doesn't run. And when I read back the device, it says it is a SX18 and the ID is just garbage.
    I'll try removing the resonator when I get a chance.
    Bean.
  • Bill ChennaultBill Chennault Posts: 1,198
    edited 2008-07-10 13:11
    Bean--
    Man! I can't resist this! ME trying to help YOU! [noparse]:)[/noparse]
    I am using one of Robert Doerr's SX48 40 pin modules in a PDB and I program it with an SX-Key (USB). I am very advanced with it, having made an LED blink quite successfully.
    I hope this helps.
    --Bill
    You are what you write.
    edited 2008-07-11 21:28
    Hmmm,
    I don't know what was wrong, but it's working fine now...
    Bean.
    Bean--
    It was doubtless my help that did it. Feel free to pass it along to others. [noparse]:)[/noparse]
    --Bill
