I2S DAC and the SX
Hello. I am trying to connect a MAX5556 stereo DAC to the SX48. I am fairly experienced with SX assembly, but completely new to audio applications. I have read the datasheet (found here: www.maxim-ic.com/quick_view2.cfm/qv_pk/4850) and some general I2S documentation, but I am having trouble understanding how this interface works. The SCLK and SDATA lines seem pretty simple. They look like a very simple synchronous serial interface. The LRCLK also seems to make sense, it controls which channel my data is going to. But the MCLK line, and all talk of MCLK/LRCLK ratios has me completely lost. Any explanation of this would be great. Thank you.
I took a quick look at the datasheet. It all looks pretty straightforward to me. It says the the device can either have data clocked into via an external clock (synchronous) or using an internal clock (asynchronous). You only need to worry about setting the internal clock speed if you want to use an asynchronous serial data stream. That's like normal RS-232 style communications. Ignore that. Just provide the clock yourself via the SCLK pin. You just need to set a bit on the SX to either high or low, and then provide a low to high transition on the SCLK pin via an SX output pin. Lather, rinse, repeat. Just keep setting your bit value followed by a low to high transition until you've transferred all your bits.
PeterM
As I mentioned in my post, "You only need to worry about setting the internal clock speed if you want to use an asynchronous serial data stream. " Look at the datasheet and on the front page under "General Description" it says, "The internal serial clock frequency is programmable by selection of a master clock (MCLK) and sample clock (LRCLK) ratio." In other words, as long as you do not communicate asynchronously with it (in other words, you manually clock MCLK as I suggested), you'll never need to handle the ratio stuff. That's all there to let the chip figure out how fast you're communicating to it when you communicate asynchronously.
If you communicate synchronously, it looks like you can do eaxctly as you suggested, e.g. hold the LCLCK line low and just listen to audio on one channel.
PeterM
