Nokia 6100 LCDs
Hey everyone. I've got a Nokia 6100 LCD from Sparkfun with the carrier board. I've been working at it all day now, and all I can get is to do it turn all pixels on, or turn all pixels off.
I know some others here have worked with this thing, but it looks like the code they've written is for the Epson controller, and I've got the Phillips. I found a .spin file where someone tried to convert the Epson driver to the Phillips LCD, but it only partially works for me ( I can initialize the LCD [noparse][[/noparse]I think]).
I would love to hear from anyone who has anything on using this with the propeller.
Thanks, Justin
Post Edited (Whelzorn) : 6/22/2008 7:06:44 PM GMT
Thanks, Justin
by googling i found this tutorial
www.sparkfun.com/tutorial/Nokia%206100%20LCD%20Display%20Driver.pdf
it contents sourccode in C
If you're half way familiar with c i think you can port the bitbanging to spin
best regards
Stefan
All I seem to be getting are shades of blue. If I send the pixel a $00 for color data, it's a slighly darker blue, and if I send a $FF, it's a little brighter. I thought the color data gave you the 256 color range?
Edit: Ok, it looks like you need to set Invert mode to ON in order to get the colors working at all. I don't know why. It works fine now though!
Thanks again!
Post Edited (Whelzorn) : 6/22/2008 9:02:07 PM GMT
Did anyone ever figure this out?
http://www.rayslogic.com/propeller/Programming/RaysStuff/Nokia/SparkfunNokia.htm
I also have a bitmap tool and code in this thread:
http://forums.parallax.com/showthread.php?p=720803
I simply cannot understand why the spin SPI is any different at all from the ASM SPI, apart from speed (and to test that, I turned the PLL down). Are there any other SPI drivers I could try?
