Help with compiling Gridrunner for the Demo/Proto/Hybrid board.
Howdy...
I just wonder if someone could try and re-compile the Gridrunner game for the Demoboard, Protoboard and the hybrid and attach the eeprom files here in this forum.
At the top of the code there are a few sections that can be un-commented and I wonder if I got the settings and the code that supposed to use the settings correctly.
Please let me know how it works.
The code can be found here, http://forums.parallax.com/showthread.php?p=732651
Since the sound driver is copyrighted I cannot attach it but OBC made a dummy driver that you can use to compile the code, http://forums.parallax.com/showthread.php?p=731721
Have fun and let me know how it works...
Living on the planet Earth might be expensive but it includes a free trip around the sun every year...
Experience level:
[noparse][[/noparse] ] Let's connect the motor to pin 1, it's a 6V motor so it should be fine.
[noparse][[/noparse] ] OK, I got my resistors hooked up with the LEDs.
[noparse][[/noparse]X] I got the Motor hooked up with the H-bridge and the 555 is supplying the PWM.
[noparse][[/noparse] ] Now, if I can only program the BOE-BOT to interface with he Flux Capacitor.
[noparse][[/noparse] ] I dream in SX28 assembler...
/Bamse
Experience level:
/Bamse
······················· movs··· VCFG, #%0000_0111······························ ' VCFG'S = pinmask (pin31: 0000_0111 : pin24)
to
······················· movs··· VCFG, #%0111_0000······························ ' VCFG'S = pinmask (pin15: 0111_0000 : pin8)
in the initialization section of the graphic driver.
Maybe it's a good idea to pass that parameter from the main file too?
(solved)
Looks like a cool game, Jeff!
I can't play it though, since I don't have a gamepad.
(has keyboard support now
Cheers,
Clemens
Post Edited (Clemens) : 6/25/2008 2:28:50 PM GMT
I'm actually not Jeff, Jeff Minter was the original coder of Gridrunner...
He really did a great job on the C-64 and this is one of my favorite games...
Keyboard support would be a good idea, but I don't really know if the Hydra uses the same driver as the Demo/Proto board...
Let me look into this...
Experience level:
/Bamse
requiring only a pin change at startup.
OBC
New to the Propeller?
Getting started with the Protoboard? - Propeller Cookbook 1.4
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card? - PropDOS
Need a part? Got spare electronics? - The Electronics Exchange
Hopefully we are getting closer to have this game running on all "platforms"...
Experience level:
/Bamse
Could someone give this a try on a demo board ?
Use the BAM_GridRunner_16.eeprom from the link in the top posting...
The keyboard controls are I, J, K, M and Space for Up, Left, Right, Down and Fire...
Hope it works...
Experience level:
/Bamse
I REALLY liked that game in highschool.
//doug
Anyhow, give the eeprom a try and let me know what you think...
Experience level:
/Bamse
