Connecting Hall Effect Sensor To BS2 — Parallax Forums
kenwtnkenwtn Posts: 250
edited 2008-06-21 14:59 in BASIC Stamp
Hi All,
···· I have several Hall Effect sensors and would like to use them with my BS2. One application would be to count wheel turns. I have done a search of the internet but can not find a schematic for connecting it to a BS2. Can anyone help me out with a schematic? I have attached a image of what I want to do.
    edited 2008-06-21 14:37
    You would need to post a datasheet or link to a datasheet for the sensor. From your picture, there are 3 leads. One can guess what they might be, but that's a quick way to destroy the device or the BS2.
    edited 2008-06-21 14:39
    A part number for the sensor would be helpful.
    - Stephen
  • kenwtnkenwtn Posts: 250
    edited 2008-06-21 14:40
    Ok thanks, here is the data sheet.
    edited 2008-06-21 14:49
    That sheet tells you all you need to know the output of the sensor should go through a 220 ohn=m resistor to a pin of the bs2.
    - Stephen
    edited 2008-06-21 14:53
    Thanks, I was not sure what value resistor to use.
    edited 2008-06-21 14:56
    I found this picture hidden on page 5 of 8 of the PDF:
    I read that I just was not sure if that would work with BS2 or not. If you think that is all I need I will go with that.
