100+ pwm waves controled from a computer?
I have a need to get 100+ pwm waves that are individually defined from a computer, anyone got any suggestions?
I am an artist and have a need to control 100+ analog panel meters, i've done this before in another project by pushing a pwm wave thorugh a transistor and pushing a load through the panel meter. http://www.timschwartz.org/paris-physical For my new project I will need to have a computer communicate with an array of microcontrolers to control a lot of these meters, like some where around 120.
I've been looking at propeller, because of the many cores, i thought it would be good to get a lot of pwm waves. But now im trying to figure out how to have a bunch of them communicate and still be able to control a lot of pwm outputs. Does anyone have any brilliant ideas? I'm looking for the easiest solution, the more code thats already out there the better. So i guess the question is what communication should i use, and how many pwms will i have to give away with that type of communication. Also, are there better solutions than propeller?
Oh and if anyone is in the souther cal area and interested in working freelance, i would love to be able to offload some of this work.
Thanks for all of your help in advance.
Cheers,
Tim
Cheers,
Tim
For even greater visual impact than panel meters, you could also drive miniature RC servos, to which you could attach a nearly limitless variety of colorful indicator pointers.
Post Edited (Phil Pilgrim (PhiPi)) : 6/17/2008 6:21:28 AM GMT
Does it even need to be PWM ? Analogue output theatre lighting desks I coded for had a DAC and then multiple switched sample and holds with an op-amp buffer follwoing, updates every 20ms. Should be easy to control to 100+ channels that way.
Oddly enough, I considered both of those options before responding. If the objective is to use just one Propeller, I'll bet either one would work fine. But I'm assuming this is a one-off design, so hardware and programming simplicity seemed paramount, and I had to consider the relative merits of five identical Prop boards without much on them versus one board with latches or S/H amplifiers. I checked DigiKey for the S/H units and found 8:1 muliplexed devices in the $15.00 range. I'm sure there's something cheaper available, but at that point I started to wonder if the more obvious approach wasn't the best. The nice thing about panel meters is that with a fast enough PWM their inductive and mechanical inertia should obviate the necessity for even an RC filter.
In which case, the simple 24 output lines to 24 meters makes a lot of sense, and it did say "easiest solution". A handful of ProtoBoards is probably insignificant to the cost of the rest of the hardware.
Beau Schwabe
IC Layout Engineer
That's certainly an interesting thought. If each meter were, say, 200mV fullscale, the duty cycle at 3.3V - 0.6V = 2.7V would only have to be 7.4% to peg the meter — well within the 10% maximum required by the multiplexing. I'd want to make darn sure the program was operational and bug-free before subjecting 100 sensitive meters to 2.7V, though!
"I'd want to make darn sure the program was operational and bug-free before subjecting 100 sensitive meters to 2.7V" -- True!!
Even worse (<-matter of perspective), there are 50mV full-scale meters as well.
Beau Schwabe
IC Layout Engineer
Yes !! use an FPGA. it's easy, ie look at this: www.fpga4fun.com/RCServos.html you need to add a serial interface to this code.
In case of propellers, I would use the same Phil option.
Regards.
Alberto.
I just ordered samples from TI and am planning on using them to drive a 4x4xRGB matrix where I need individual RGB controls for each element. They sent me 10 for free. If it works you could control 160 meters with only 2 pins for I2C for free. The chip has it's own internal osc so you wont even need much in the way of support components. You can set up to 14 unique addresses for the chip so you should be able to put all of them on the same bus.
http://focus.ti.com/docs/prod/folders/print/tlc59116.html
Post Edited (Nat'n) : 6/19/2008 7:43:56 PM GMT
That's quite the find! It looks like setting Rext to a high enough value will be adequate to keep the drive current within almost any meter's specs.
Did you know the TLC5940 ??
Here on the forum there are some drivers fo it. I made a LED screen with those chips.
Regards.
Alberto.
There is a little bit more involved with the hardware interface on the TLC5940, but, on the other hand, if I use them I can avoid using SSOP breakouts when I am prototyping. They are higher resolution too, but at this point, I can't imagine why I would need 4096 steps in an RGB application like this (illuminated buttons). 68+ billion colors is a few orders of magnitude more than I think I can discern.
The fact that drivers already exist is a good thing though. Perhaps I will build it both ways just for fun. Besides, I can tell people it's got 68 billion colors!
