Since your question is off-topic I am moving it to the Sandbox Forum.· Trimmer pots are quite often multi-turn to facilitate finer adjustments. Even when they are not they are often built to be adjusted easily with a screwdriver from either a horizontal or vertical position. These ¾ turn pots don’t usually have any kind of shroud that is typical on standard potentiometers.
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Chris Savage Parallax Tech Support
Correct. Of course, you should always observe the power rating as this can vary between the two types. One other difference I almost forgot about is that Trimmer pots are pretty much always linear devices, whereas standard potentiometers can be linear or logarithmic.
I strongly suspect there are two important differences in timmer pots and other pots.
A. a wear factor. Timmer pots were originally set and forget items, not intended for analog controls that are accessed on a front panel, like a volume control. A lot of motion may quickly wear them out.
B. a power factor. Timmer pots are generally very low power. These days, a lot of them are 1/10th of a watt or less. Traditional pots for tube hifi and other applications might be able to handle 5 watts or more.
Chris Savage
Chris Savage
i am sure it wont make much difference
