trimmers pots vs. pots — Parallax Forums
Bobb FwedBobb Fwed Posts: 1,119
edited 2013-05-20 07:35 in General Discussion
I am curious what the difference between potentiometers vs. trimmer potentiometers, or is there one?
    edited 2008-06-16 16:12
    Bobb,
    Since your question is off-topic I am moving it to the Sandbox Forum.· Trimmer pots are quite often multi-turn to facilitate finer adjustments. Even when they are not they are often built to be adjusted easily with a screwdriver from either a horizontal or vertical position. These ¾ turn pots don’t usually have any kind of shroud that is typical on standard potentiometers.
  • Bobb FwedBobb Fwed Posts: 1,119
    edited 2008-06-16 16:35
    but electronically they function the same, right?
    edited 2008-06-16 16:46
    Correct. Of course, you should always observe the power rating as this can vary between the two types. One other difference I almost forgot about is that Trimmer pots are pretty much always linear devices, whereas standard potentiometers can be linear or logarithmic.
    edited 2008-06-16 16:53
    thanks
  • sameer xzxsameer xzx Posts: 2
    edited 2013-05-20 06:26
    will there be any change if i put trimmer rather than putting pot
    edited 2013-05-20 06:39
    A trimmer is a pot (POTentiometer), just with a different mechanical arrangement. They're actually called "trimmer pots" or "trim pots".
    edited 2013-05-20 07:28
    so, now i can use trimmer in place of pot
    i am sure it wont make much difference
    I strongly suspect there are two important differences in timmer pots and other pots.
    A. a wear factor. Timmer pots were originally set and forget items, not intended for analog controls that are accessed on a front panel, like a volume control. A lot of motion may quickly wear them out.
    B. a power factor. Timmer pots are generally very low power. These days, a lot of them are 1/10th of a watt or less. Traditional pots for tube hifi and other applications might be able to handle 5 watts or more.
