Interrupts
Is there a way to do interrupts with the javelin stamp as there is with the SX chip? I want to have a light blinking in the background while the main loop is doing things that take lots of time.
marshall edgell
marshall edgell
in the background.
If you select
static int highTime = (short)57600;
static·int lowTime = (short)57600;
you should get a pulsing led (0.499968 sec off, 0.499968 sec on)
static PWM led = new PWM(CPU.pin12,highTime,lowTime);
Put a 470 ohm resistor in series with the led.
regards peter
marshall
